MHB Finding $\angle ACB$ in $\triangle ABC$
  • Thread starter Thread starter Albert1
In triangle ABC, with angle ABC measuring 45 degrees, point D lies on line segment BC such that 2BD equals CD, and angle DAB is 15 degrees. Participants discuss various approaches to find angle ACB, emphasizing the importance of geometric methods. Despite attempts to solve the problem geometrically, some contributors express frustration at their lack of success. The conversation highlights the challenge of applying geometric principles effectively in this context. Ultimately, the goal remains to determine the measure of angle ACB.
Albert1
$\triangle ABC ,\angle ABC =45^o,\,\,point \,\, D \,\, on \,\, \overline{BC}, \,\,and :$
$2\overline {BD}=\overline {CD},\,\,\angle DAB=15^o$
please find :$\angle ACB=?$
Mathematics news on Phys.org
My solution:
This is most likely not what you're looking for but I couldn't resist to solve any given geometry problem with the help of my close friend, aka trigonometry, hehehe...:p:o
First let $BD=DE=EC=k$ and join DG and GF such that $\angle ABC=45^{\circ}=\angle DGB$, $\angle GDF=30^{\circ}=\angle DFG$ and $\angle DAB=15^{\circ}=\angle AGF$ so triangles $DBG$, $DGF$ and $AGF$ are isosceles with the congruent sides labeled as $k$.
Applying the Sine Rule to the triangle $DFG$ we have
$\dfrac{DF}{\sin 120^{\circ}}=\dfrac{k}{\sin 30^{\circ}}\,\,\,\implies DF=\sqrt{3}k$
Applying the Cosine Rule to the triangle $ACD$ we get
$AC^2=(2k)^2+((1+\sqrt{3})k)^2-2(2k)(1+\sqrt{3})k)\cos 60^{\circ}\,\,\,\implies AC=\sqrt{6}k$
Applying the Sine Rule again to the triangle $ACD$ we see that
$\dfrac{AC}{\sin 60^{\circ}}=\dfrac{AD}{\sin ACB}$
$\sin ACB=\dfrac{1+\sqrt{3}}{2\sqrt{2}}=\dfrac{1}{2}\cdot\dfrac{1}{\sqrt{2}}+\dfrac{\sqrt{3}}{2}\cdot\dfrac{1}{\sqrt{2}}=\sin 30^{\circ}\cos 45^{\circ}+\cos 30^{\circ}\sin 45^{\circ}=\sin(30^{\circ}+45^{\circ})=\sin 75^{\circ}$
$\therefore \angle ACB=75^{\circ}$.
anemone said:
My solution:
your answer is correct !,will you try to use geometry ?
(let geometry also be your close friend)
I in fact tried to tackle it geometrically and I thought it must have everything to do to prove that
the quadrilateral $AGDC$ is cyclic
but all of my attempts had been proven to be exercises in futility.(Doh)
My solution:
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
