Finding average horizontal force?
In summary, The average force acting on a 150lb driver while the car came to rest was calculated by using the equation E = F∆x, where E is the work done, F is the average force, and ∆x is the distance traveled. This was based on the assumption that the acceleration and therefore the force were constant. The collision-time was determined by finding the average velocity using the equation Vavg = (Vi + Vf)/2 and using it to find the time by rearranging the equation Vavg * time = ∆x. This approach may not be entirely accurate as it does not take into account the varying force during the crash, but it provides an estimate for the
IDespisePhysics
A car is traveling at 60.0mph when it collides with a stonewall. The car comes to rest after the first foot of the car is crushed. What was the average horizontal force acting on a 150lb driver while the car came to rest?
I'm not a hundred percent sure which equations to use but, I searched through questions I've had in the past and found an example however, it deals with distance.
vf^2=vi^2+2ax
SIGMA F= MA
Again, I wasn't quite sure where to even start so, I decided to find acceleration because I thought it might be important with SIGMA F=MA. I've listed the givens which, may or may not be correct.
Vi = 60MPH ---> 88 FT Per Second
Vf = 0 m/s
m = 150lbs
If I told you how long the collision lasted, would you be able to tell me the average force?
Do you mean time?
If so, I think I would.
IDespisePhysics said:
Do you mean time?
Yes I mean the time that it took the car to come to rest from when it first touched the wall.
Specifically, if I say the collision-time is T, then tell me what the average force is.If you can figure out the average force based on the duration of the collision, then the problem becomes a problem of finding "how long did the collision last?"
Any ideas about how to find how long the collision lasted?
I'm not sure. I do know that Impulse is a force applied over a period of time. J=Ft
And I also know that mΔv = Ft.
I'm so sorry. I honestly don't understand this question. I get that I need to find time in order to help find acceleration to find ∑F. However, this is a collision problem, so wouldn't I have to use momentum? Yet the collision equation needs two masses and two velocities in order to find it. I know this is possibly off topic to your original question and I honestly apologize. Is there something that I'm not seeing? The equations given by my teacher do not help.
Good.
Indeed, the way you would use momentum is in the above equation, m∆v=Ft
I have a feeling you might have been asking "wouldn't I have to use momentum conservation?"
Conservation of momentum isn't useful here. The car is essentially colliding with the entire Earth (in a sense) because the momentum that it loses is gained by the Earth. You can't hope to measure the insignificant change in velocity of the Earth (and even if you could, it wouldn't be useful for what we're trying to find).About the problem,
You can pretend the force on the person is always equal to the average force. What this means is that the force is constant, which means that the acceleration is constant.
So you want to find how long the collision lasted. You know 3 things:
You know the acceleration is constant (which is not true, but if we only care about the average force, then that is how we treat the situation)
You know the initial velocity
And you know how far the car traveled in the collision-time
(You were told the car was crushed by 1 foot, so how far did the car travel from the moment it first touched the wall to the moment it stopped moving?)
You'll have to use those 3 pieces of information to find the collision-time.
Vi = 88 ft per second
a= 0 m/s ^2
x = 1 ft
Would I have to use the kinematics equation, x=vit + (1/2)at^2, in order to find time?
Also, are any of my givens incorrect?
Would I end up using quadratic or is that too far?
a= 0 m/s ^2
x = 1 ft
a = 0? That doesn't make sense. There is an average force acting on the person Favg, so the acceleration would be Favg/m
but anyway the value of a is not important
It isn't necessary. Do you know an equation for the average velocity given that acceleration is constant? Use that to find [itex]V_{avg}[/itex] and then find the time by [itex]V_{avg}[/itex]*time=distance
That is the key question here.
If the acceleration is constant then the force is constant, and you can use ##E = F\Delta s##. And since you are given no other way to solve the question, it seems you are expected to assume constant force. Yet the question asks for average force. If the force varies then you do not have enough information. Finding the duration is crucial.
At this point you have my permission to sack the problem setter - he or she has inadequate expertise to be teaching physics.
In a car crash, the force obviously starts low but rapidly increases. In a well designed car body, the force should rise to its maximum quite quickly and stay at about the same value as long as possible. This minimises the maximum force exerted on passengers. So taking the force to be constant might be reasonable, but the question should tell you to assume that it is.
Hello haruspex,
The formula you suggested; I've never seen it before. What does it mean?
So, I need to find an equation that equals V avg?
If so, I have Vi+Vf/2.
I'm not sure if acceleration is constant in that equation.
And if that is correct, I can use Vavg / x = t, right?
Hello haruspex,
Work = force times distance.
Yes, it assumes constant acceleration.
That's dimensionally wrong. Try again.
Related to Finding average horizontal force?
1. What is average horizontal force?
Average horizontal force refers to the average amount of force acting on an object in a horizontal direction.
2. How do you calculate average horizontal force?
To calculate average horizontal force, you would need to divide the total horizontal force by the number of forces acting on the object in a horizontal direction.
3. What are some common applications of finding average horizontal force?
Finding average horizontal force is commonly used in physics and engineering to analyze the effects of forces on structures and objects, such as calculating the average force on a bridge or the average force needed to move an object horizontally.
4. Is average horizontal force the same as net horizontal force?
No, average horizontal force and net horizontal force are two different concepts. Average horizontal force refers to the average amount of force acting on an object in a horizontal direction, while net horizontal force is the sum of all the horizontal forces acting on an object.
5. What factors can affect the average horizontal force on an object?
The average horizontal force on an object can be affected by factors such as the mass of the object, the angle of the force, and any other forces acting on the object in a horizontal direction.
