Finding bases for ##W_1\cap W_2## and ##W_1+W_2##
In summary: In other words, the only way to combine these vectors to get zero is to multiply them all by zero.This is not the case for the matrix with which we are dealing.The reason we solve the equation is to find the constants ##c_1, c_2, c_3, c_4## that make the equation true, and in this case, there is no unique solution. This is why the solution is expressed in terms of parameters - you can choose any values for the parameters, and the resulting vectors will still be linear combinations of the vectors in ##W_1## and ##
Terrell
317
Let ##W_1=\langle (1,2,3,6),(4,-1,3,6)(5,1,6,12))\rangle## and ##W_2=\langle (1,-1,1,1),(2,-1,4,5)\rangle## be subspaces of ##\Bbb{R}^4##. Find the bases for ##W_1\cap W_2## and ##W_1+W_2##.
##\alpha(1,2,3,6)+\beta(4,-1,3,6)=\gamma(1,-1,1,1)+\delta(2,-1,4,5)##
I began by determining if the vectors in ##W_1## are linearly independent, then found out that ##dim(W_1)=2##, then likewise ##dim(W_2)=2## and ##W_2## is linearly independent. Now would it be correct to put the basis vectors of ##W_1## & ##W_2## in a matrix to find ##W_1\cap W_2##? Since if I let ##\{(1,2,3,6),(4,-1,3,6)\}## and ##\{(1,-1,1,1),(2,-1,4,5)\}## be bases for ##W_1## & ##W_2##, respectively, then ##W_1\cap W_2## can be expressed in the following equation ##\alpha(1,2,3,6)+\beta(4,-1,3,6)=\gamma(1,-1,1,1)+\delta(2,-1,4,5)## which can be solved by performing r.r.e.f. on the following matrix
\begin{bmatrix}
1 & 4 & 1 & 2 \\
2 & -1 & -11 & -1\\
3 & 3 & 1 & 4\\
6 & 6 & 1 & 5\\
\end{bmatrix}
I then obtained
\begin{bmatrix}
1 & 0 & 0 & 0.\overline{7} \\
0 & 1 & 0 & -0.\overline{4}\\
0 & 0 & 1 & 3\\
0 & 0 & 0 & 0\\
\end{bmatrix}
Does this mean that ##W_1\cap W_2## is a point/vector in 4-D space?
Furthermore, a basis for ##W_1+W_2## is the set ##\{(1,2,3,6),(4,-1,3,6),(1,-1,1,1)\}##. I need help since my book didn't provide a solution.
\begin{bmatrix}
1 & 4 & 1 & 2 \\
2 & -1 & -11 & -1\\
3 & 3 & 1 & 4\\
6 & 6 & 1 & 5\\
\end{bmatrix}
I then obtained
\begin{bmatrix}
0 & 0 & 1 & 3\\
0 & 0 & 0 & 0\\
\end{bmatrix}
First off, let's look at the geometry here. ##W_1## can be seen by inspection to be a plane in ##\mathbb R^4## (the 3rd vector in the set is the sum of the first two). ##W_2## is also a plane, since neither vector is a multiple of the other.
In the first matrix of your work above, you are solving the equation ##c_1\vec{v_1} + c_2\vec{v_2} + c_3\vec{v_3} + c_4\vec{v_4} = \vec 0## for the constants ##c_1, c_2, c_3, c_4##. Here ##v_1## and ##v_2## are in ##W_1## and the other two vectors are in ##W_2##.
Assuming your work in the second matrix is correct (I didn't check), what is this matrix saying about the constants ##c_1, c_2, c_3, c_4##?
Points and vectors are different things. A vector consists of an infinite number of points. If your matrix had row-reduced to an identity matrix, that would mean that the solution is a unique point.
Mark44 said:
Assuming your work in the second matrix is correct (I didn't check), what is this matrix saying about the constants c1,c2,c3,c4c1,c2,c3,c4c_1, c_2, c_3, c_4?
I think it is saying that ##0.\overline{7}\overrightarrow{v_1} -0.\overline{4}\overrightarrow{v_2}=-3\overrightarrow{v_3}-\overrightarrow{v_5}##. Which in english means that as long as this parametric relationship is maintained, then this particular combination of vectors from ##W_1## and ##W_2## meet at a point in space. This continuity of points should trace a line in space. Is this a correct interpretation?
Why?
Terrell said:
I then obtained
##\begin{bmatrix}
0 & 0 & 1 & 3\\
0 & 0 & 0 & 0\\
\end{bmatrix}##
Terrell said:
I think it is saying that ##0.\overline{7}\overrightarrow{v_1} -0.\overline{4}\overrightarrow{v_2}=-\overrightarrow{v_3}-\overrightarrow{v_5}##. Which in english means that as long as this parametric relationship is maintained, then this particular combination of vectors from ##W_1## and ##W_2## meet at a point in space. This continuity of points should trace a line in space. Is this a correct interpretation?
No, it isn't. The matrix I was talking about, copied above, says this:
##c_1 = -7/9~c_4\\
c_2 = 4/9 c_4\\
c_3 = -3c_4\\
c_4 = c_4##
In other words, if we let ##c_4 = 1##, which we can do because it is arbitrary, ##-\frac 7 9 \vec{v_1} + \frac 4 9 \vec{v_2} - 3 \vec{v_3} + \vec{v_4} = \vec 0##. Since not all of the constants are 0, then the four vectors are linearly dependent. These four vectors are the columns of the first matrix, taking into account a typo you made in the 2nd entry of ##\vec{v_3}##.
You can also infer from the 2nd matrix that the vectors ##\vec{v_1}, \vec{v_2}, \vec{v_3}## are linearly independent, and would form a basis for ##W_1 + W_2##.
Terrell said:
Why?
That point would be (0, 0, 0 0), which would mean that ##c_1 = c_2 = c_3 = c_4 = 0##, and this would be the unique solution to the equation ##c_1\vec{v_1} + c_2\vec{v_2} + c_3\vec{v_3} + c_4\vec{v_4} = \vec 0##. This would imply that these four vectors are linearly independent. In that case, ##W_1 + W_2## would be all of ##\mathbb R^4##.
c1=−7/9 c4c2=4/9c4c3=−3c4c4=c4c1=−7/9 c4c2=4/9c4c3=−3c4c4=c4c_1 = -7/9~c_4\\ c_2 = 4/9 c_4\\ c_3 = -3c_4\\ c_4 = c_4
In other words, if we let c4=1c4=1c_4 = 1, which we can do because it is arbitrary, −79→v1+49→v2−3→v3+→v4=⃗0−79v1→+49v2→−3v3→+v4→=0→-\frac 7 9 \vec{v_1} + \frac 4 9 \vec{v_2} - 3 \vec{v_3} + \vec{v_4} = \vec 0. Since not all of the constants are 0, then the four vectors are linearly dependent. These four vectors are the columns of the first matrix, taking into account a typo you made in the 2nd entry of →v3v3→\vec{v_3}.
I do know and understand this idea to begin with, but what I do like to know is how can we use this equation/relationship to determine the intersection of ##W_1## and ##W_2## which I believe is a line, since the intersection of two plane must be a line. Moreover, also determine the equation of that line of intersection.
Yes, ##W_1## and ##W_2## are planes in ##\mathbb R^4##. For a couple of reasons, which I won't go into, these planes intersect in a line (not a point -- that can't happen).
##W_1 = \{\vec{w_1} \in \mathbb R^4~ |~ \vec{w_1} = a\vec{v_1} + b\vec{v_2}\}##, with a and b being real numbers.
##W_2 = \{\vec{w_2} \in \mathbb R^4~ |~ \vec{w_2} = c\vec{v_3} + d\vec{v_4}\}##, with c and d being real numbers.
Here ##\vec{v_1}## and ##\vec{v_2}## are the first two columns of your first matrix, and ##\vec{v_3}## and ##\vec{v_4}## are the last two columns.
Set ##\vec{w_1} = \vec{w_2}## and solve this matrix equation, and you should get your solution -- a line in parametric form.
Likes Terrell
Here is what I obtained, ##\alpha(1,2,3,6)+\beta(4,-1,3,6)=\gamma(1,-1,1,1)+\delta(2,-1,4,5)##
\begin{align}
\Longleftrightarrow
\left[\begin{matrix}
1 & 4 & -1 & -2\\
2 & -1 & 1 & 1\\
3 & 3 & -1 & -4\\
6 & 6 & -1 & -5\\
\end{matrix}\right]
\cdot
\alpha\\
\beta\\
\gamma\\
\delta\\
\end{matrix}\right]
0\\
0\\
0\\
0\\
\end{matrix}\right]\\
\end{align}
\begin{align}
\alpha - \frac{9}{7}&=0\\
\beta + \frac{4}{9}&=0\\
\gamma + 3\delta&=0\\
\end{align}
Therefore, the parametric form of the line is ##(\alpha,\beta,\gamma,\delta)=t(9/7, -4/9, -3, 1)## such that ##t## is a free variable, and the cartesian form of the line is ##36\delta=28\alpha-81\beta-12\gamma##.
What I see intuitively is that ##(\alpha,\beta,\gamma,\delta)=t(9/7, -4/9, -3, 1)## is the subspace that gets mapped to ##(0,0,0,0)## by the transformation matrix \begin{bmatrix} 1&4&-1&-2\\ 2&-1&1&1\\ 3&3&-1&-4\\ 6&6&-1&-5\end{bmatrix}.
However, I don't intuitively understand how this "solution vector",##(\alpha,\beta,\gamma,\delta)=t(9/7, -4/9, -3, 1)##, is the intersection between the plane formed by vectors ##(1,2,3,6)## & ##(4,-1,3,6)## and the plane formed by vectors ##(1,-1,3,6)## & ##(2,-1,4,5)##.
After reading a book, I realized the post I was reading from a different site is incorrect and my initial understanding of how this must be solved was correct. So please ignore my previous two posts.
Correction: equating ##\alpha(1,2,3,6)+\beta(4,-1,3,6)=\gamma(1,-1,1,1)+\delta(2,-1,4,5)##, I then need to solve
##\left[\begin{matrix}1&4&-1&-2\\2&-1&1&1\\3&3&-1&-4\\6&6&-1&-5\\\end{matrix}\right]\left[\begin{matrix}\alpha\\\beta\\\gamma\\\delta\end{matrix}\right]=\left[\begin{matrix}0\\0\\0\\0\\\end{matrix}\right]\Rightarrow \left[\begin{matrix}\alpha\\\beta\\\gamma\\\delta\end{matrix}\right]=\frac{7}{9}\left[\begin{matrix}1\\2\\3\\6\end{matrix}\right]-\frac{4}{9}\left[\begin{matrix}4\\-1\\3\\6\end{matrix}\right]=-3\left[\begin{matrix}1\\-1\\1\\1\end{matrix}\right]+\left[\begin{matrix}2\\-1\\4\\5\end{matrix}\right]##
This method is the correct one right? thank you!
Looks OK to me. One way to check would be to find the equations of the two planes, which could be done by finding a normal to each plane using the dot product. Once you have a normal and a point on the plane (such as (0, 0, 0, 0)), you can write the equation of that plane. The vector you found should satisfy each of the two planes.
Likes Terrell
will keep that in mind. thank you alot!
Related to Finding bases for ##W_1\cap W_2## and ##W_1+W_2##
What does "finding bases" mean in the context of ##W_1\cap W_2## and ##W_1+W_2##?
Finding bases refers to finding a set of vectors that span the vector space of the intersection (##W_1\cap W_2##) or sum (##W_1+W_2##) of two subspaces, respectively. These bases are important because they allow us to represent any vector in these subspaces as a linear combination of the basis vectors.
How do you find a basis for ##W_1\cap W_2##?
To find a basis for ##W_1\cap W_2##, you can use the method of Gaussian elimination to reduce the matrices representing the subspaces to reduced row echelon form. The columns with leading 1s in this form will form a basis for the intersection.
Is the basis for ##W_1\cap W_2## unique?
No, the basis for ##W_1\cap W_2## is not unique. There are many different sets of vectors that can span the same subspace. However, any basis for ##W_1\cap W_2## will have the same number of vectors, which is equal to the dimension of the intersection.
Can you use the same method to find a basis for ##W_1+W_2##?
Yes, you can use Gaussian elimination to find a basis for ##W_1+W_2## as well. However, in this case, the basis will not necessarily be unique. Any set of vectors that spans the sum of the two subspaces can be considered a basis, and different methods may result in different bases.
Why is finding bases for ##W_1\cap W_2## and ##W_1+W_2## important?
Finding bases for these subspaces allows us to gain a deeper understanding of the structure and properties of the subspaces. Bases also make it easier to perform calculations and solve problems involving vectors in these subspaces, as we can represent them in terms of a finite set of basis vectors.
  • Linear and Abstract Algebra
