- 2,168
- 193
I am using WSL2/Ubuntu 20.04 on Windows 10 to run a specific cosmological parameter estimation program called Cobaya. (It only runs on Linux and Mac)
Here are my specs.
Cobaya uses the MCMC method for parameter estimation. I wonder what can be the best/optimum `mpirun ...` command to fully utilize my computer's specs for the MCMC task in WSL2/Ubuntu.
I have searched a bit, and choosing the correct `mpirun` arguments can impact the time it runs. Since my computer is nearly garbage for data analysis, I need to select the right ones.
Here is the page of the OpenMPI (https://www.open-mpi.org/doc/v3.0/man1/mpirun.1.php)
Normally I am using, `mpirun -n 2 cobaya-run test.yaml`. Even it seems I have 4 cores. I can only use 2. I guess to use all 4 cores. I can use `mpirun --use-hwthread-cpus cobaya-run test.yaml`.
Should I make some changes as well or just using `mpirun --use-hwthread-cpus cobaya-run test.yaml` will be enough ?
Here are my specs.
Code:
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 39 bits physical, 48 bits virtual
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 2
Core(s) per socket: 2
Socket(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 142
Model name: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
Stepping: 9
CPU MHz: 2711.999
BogoMIPS: 5423.99
Hypervisor vendor: Microsoft
Virtualization type: full
