MHB Finding border points and then interior points
  • Thread starter Thread starter A.Magnus
    Interior Points
A.Magnus
I am working on a classical real analysis problem as follow:
Find $int (A)$ and $bd (A)$ if $A = \{ \frac{1}{n} | n \in \mathbb N \}= \{ \frac{1}{1}, \frac{1}{2}, \frac{1}{3}, ... \}$.
The answers from solution manual are respectively $ int (A) = \emptyset$ and $bd (A) = \{0\} \cup \{ \frac{1}{n} | n \in \mathbb N \}$. And here are my textbook's definition of interior point and border point:
Let $A \subseteq \mathbb R$. A point $x$ in $\mathbb R$ is an interior point of A if there exists a neighborhood $N$ of $x$ such that $N \subseteq A$. If for every neighborhood of $N$ of $x$, $N \cap A \neq \emptyset$ and $N \cap A^c \neq \emptyset$, then $x$ is a border point of $A$.
And then there is also this:
Every point $x \in A$ is either interior or border point of $A$.
To my inexperienced mind, the answer to $int (A) = \emptyset $ is understandable because while neighborhood $N (x | \epsilon >0)$ is an open set (per textbook), but $A = \{ \frac{1}{1}, \frac{1}{2}, \frac{1}{3}, ... \}$ is incomplete, meaning that there is gap between any two consecutive elements of $A$. Therefore by technicality $N (x | \epsilon )$ does not exist inside $A$. (Am I correct here?)
The answer to $bd (A) = \{0\} \cup \{ \frac{1}{n} | n \in \mathbb N \}$ is understandably the direct consequence of $int (A) = \emptyset $, i.e., if none of the elements of $A$ is interior point, then all of them must be border points, plus the zero.
But what troubles me is this: What happens if I instead answer $int(A)$ first and then $bd (A)$ second? Am I going to get the same answers?
(i) For $\{0\}$, I was tempted to conclude that zero is indeed a border point because $N (0 | \epsilon) \cap A \neq \emptyset$ and $N (0 | \epsilon) \cap A^c \neq \emptyset$ for all $\epsilon >0$. But had I not just concluded above that $N (x | \epsilon)$ does not exist in $A$?
(ii) How about for the rest of the points, i.e., $\frac{1}{n}$? How do I conclude $N (\frac{1}{n} | \epsilon ) \cap A \neq \emptyset$ and $N (\frac{1}{n} | \epsilon ) \cap A^c \neq \emptyset$ for all possible $\epsilon >0$?
I think I must have missed something here. Any help would therefore be very much appreciated. Thank you for your time and gracious help. ~MA
Hi MaryAnn.
You mean to say that for all $\epsilon>0$, $N(x\mid\epsilon)\not\subseteq A$, because $N(x\mid\epsilon)$ contains points not in $A$. For example, for $x=\frac13$, given $\epsilon>0$, let
$$\delta=\min\left\{\frac{\epsilon}2,\frac{\frac13-\frac14}2\right\};$$
then $y=x-\delta\not\in A$ but $y\in N(x\mid\epsilon)$. (If all this looks confusing to you, try sketching the points on a number line.) In general, if $x=\frac1n$, let
$$\delta=\min\left\{\frac{\epsilon}2,\frac{\frac1n-\frac1{n+1}}2\right\};$$
and $y=x-\delta$ as above. Hence there does not exist any $x$ such that $x$ is an interior point of $A$ (not that $N (x | \epsilon )$ does not exist).
You can do whichever one first, it doesn’t really matter. If you do everything correctly, you should get the same answers.
See above. Note also that in the above you were taking $x\in A$ whereas now you are considering $0$, which is not in $A$.
For $x\in A$, $N (x | \epsilon)\cap A$ is clearly not going to be empty because it contains $x$ itself. It also contains points not in $A$ by the method outlined in (i) above. Hence every point in $A$ is a border point. For points outside $A$, $0$ is the only point that is a border point. Given any $\epsilon>0$, $N(0\mid\epsilon)$ contains a point in $A$ (namely $\frac1N$ where $N$ is any integer greater than $\frac1\epsilon$) and also a point not in $A$ (namely $0$ itself). For any $x\not\in A$ and $x\ne0$, let
$$\epsilon=\tfrac12\inf\left\{\{|x|\}\cup\{|x-a|:a\in A\}\right\};$$
then $N (x | \epsilon)\cap A$ does not contain any point in $A$ and so $x$ can’t be a border point.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
