Finding centre of mass of a semicircular lamina
In summary: Re: finding centre of mass of a semicircular laminaRemember that You have to perform the following steps... a) compute the mass of the lamina... $\displaystyle M= \int \int_{L} \delta (x,y)\ dx dy$ (2)b) compute the coordinates of the center of mass... $\displaystyle x_{g}= \frac{1}{M}\ \int \int_{L} x\ \delta(x,y)\ dx dy$$\displaystyle y_{g}= \frac{1}{M}\ \int \int_{L} y\ \delta
candy1
Suppose the density of any point on a semicircular lamina {(x, y) : x >= 0,\(\displaystyle x^2 + y^2\) <= r^2 is proportional to its distance from the origin. Compute the centre of mass.
I am trying to figure out what is the density function for this case.
The lamina here is the right half of a circular disk of radius $r$ centered at the origin.
What is the density function $\rho(x)$ and what kind of symmetry may we use?
Yaa.. that's what I am trying to figure out.. the density function.. and after that its pretty straight forward.
We are told the density at some point $P(x,y)$ is proportional to the point's distance from the origin. What is the distance of $P$ from the origin?
If the task is to find the coordinates x and y of the center of mass, the density function can be supposed to be... $\displaystyle \delta (x,y)= \sqrt{x^{2}+ y^{2}} $ (1)
$\displaystyle y_{g}= \frac{1}{M}\ \int \int_{L} y\ \delta(x,y)\ dx dy$ (3)
Kind regards
$\chi$ $\sigma$
Are you saying you do not know what "proportional" means? Or that you do not know what the distance from the origin is?
I would suggest changing to polar coordinates.
FAQ: Finding centre of mass of a semicircular lamina
How do you find the centre of mass of a semicircular lamina?
To find the centre of mass of a semicircular lamina, you can use the formula:
x̅ = (4R)/(3π)
y̅ = (8R)/(9π)
where R is the radius of the semicircle. This formula takes into account the shape and distribution of mass in the semicircular lamina.
Can the centre of mass be outside of the semicircular lamina?
No, the centre of mass of a semicircular lamina will always be located within the boundaries of the lamina. This is because the centre of mass is the point at which the entire mass of the object can be considered to be concentrated.
Does the density of the semicircular lamina affect the centre of mass?
Yes, the density of the semicircular lamina will affect the location of the centre of mass. The formula for finding the centre of mass takes into account the mass distribution of the object, so a change in density will result in a change in the location of the centre of mass.
Is it necessary to know the mass of the semicircular lamina to find the centre of mass?
Yes, the mass of the semicircular lamina is a crucial component in determining the centre of mass. Without knowing the mass, the formula for finding the centre of mass cannot be accurately applied.
Can the centre of mass of a semicircular lamina be located at the edge of the semicircle?
No, the centre of mass of a semicircular lamina will always be located along the vertical diameter of the semicircle. This is because the semicircular lamina has a symmetrical shape, and the centre of mass will be located at the point of symmetry.
