Finding centripetal acceleration and velocity
In summary, centripetal acceleration and velocity refer to the acceleration and velocity of an object moving along a circular path. Centripetal acceleration is calculated using the formula a = v^2/r, while centripetal velocity is calculated using the formula v = 2πr/T. These measurements are typically expressed in meters per second squared (m/s^2) and meters per second (m/s), respectively. Centripetal acceleration and velocity are directly related to the centripetal force, which is responsible for keeping an object in circular motion. Real-life examples of centripetal acceleration and velocity can be seen in activities such as driving around a curve, riding a rollercoaster, and orbiting satellites.
FreshyT
a) After take-off an airplane takes a U-turn tilting the plane 45 degrees to one side. The speed and height is constant. Find the centripetal acceleration.
Mass: 79010 kg
Engine Fmax: 2x 121.4 kN
b) The U-turn took 47 seconds. What is the velocity in km/h of the airplane now?
a) as = g*tan angle = 9.81 m/s * tan 45 = 9.81 m/s is the centripetal acceleration.
b) I can't find any formulas on this... ?
What effects does the centripetal acceleration have on velocity?
Related to Finding centripetal acceleration and velocity
1. What is centripetal acceleration and velocity?
Centripetal acceleration and velocity refer to the acceleration and velocity of an object moving along a circular path. Centripetal acceleration is the change in velocity of an object due to its change in direction, while centripetal velocity is the speed at which the object is moving along the circular path.
2. How do you calculate centripetal acceleration and velocity?
Centripetal acceleration can be calculated using the formula a = v^2/r, where a is the acceleration, v is the velocity, and r is the radius of the circular path. Centripetal velocity can be calculated using the formula v = 2πr/T, where v is the velocity, r is the radius, and T is the period of the circular motion.
3. What units are used to measure centripetal acceleration and velocity?
Centripetal acceleration is typically measured in meters per second squared (m/s^2), while centripetal velocity is measured in meters per second (m/s).
4. How is centripetal acceleration and velocity related to the centripetal force?
Centripetal acceleration and velocity are directly related to the centripetal force, which is the force that keeps an object moving in a circular path. The greater the centripetal force, the greater the acceleration and velocity of the object.
5. What are some real-life examples of centripetal acceleration and velocity?
Some examples of centripetal acceleration and velocity in everyday life include a car turning around a curve, a rollercoaster going around a loop, a satellite orbiting the Earth, and a gymnast performing a routine on the uneven bars.
