Finding coincident angle between 2 equally spaced sets
  • Thread starter Telosian 7
In summary, "Finding coincident angle between 2 equally spaced sets" involves determining the angle at which two sets of points, evenly distributed around a circle, align or overlap. This process requires calculating the angular positions of each set and identifying the angles that correspond to their intersections, which can be useful in various applications such as signal processing, geometry, and design.
Telosian 7
Hi Math people. Budding math wiz here (Aerospace Engineer / Coordinate measuring machine programmer) , need help with a formula.
I have 2 external gears on one shaft, the top gear has 12 equally spaced teeth and bottom has 14 equally spaced teeth. At some location there will be 2 gears visually/nominally in-line or at the same rotation angle around 360°. Assuming a part is loaded and a top tooth or angle value is randomly measured, (this value will be positive from 0-360°). Assume we then measure an arbitrary adjacent tooth on the gear set below the top one. I have these values, and can store these as variables. My program I am using for this purpose is fairly basic, has some algebra and trig, but barely an if/then statement. I need to map or calculate all other tooth positions (angle position) for each gear set, and ideally 'wrap' them to 360 (e.g. 395 = 35). From there I need to find the smallest angle difference between any one tooth on top and adjacent tooth on bottom. Keeping in mind a value of 7 on one gear and a value of 355 on the other is a circular distance or delta of only 12, and not 348.
The trouble is in my experiment (assuming 12T has a start value of 60 (2 pitches), and 14T has a start value of 51.428 (also approx 2 pitches), how could I calculate and find out that 12T gear # 11 and 14T #13 are the teeth 'in-line' or rotationally coincident around 360°? my functions available are : + - / *, MIN ,MAX ABS, < or > , ATAN, ASIN, COS, SIN, and I dont have if/then, else, for, while, loops or patterns, best I have is 'jump to step', I can only jump ahead but I have discovered a clever way of testing things with a boolean ... e.g. STEP1 : (A>B*1)+2 will go to step 2 if false but step 3 if true. Anyways I need less help with programming and more with a simplified formula. Thank you math Team - I have exhausted my options for days on ChatGPT. Obviously, I can compare gear 1 tooth 1 to all 14 teeth on gear 2, and so on for all 12 teeth on one gear for 168 comparisons, would take lots of manual coding I think there must be a way with angular pitch ratios etc. Cheers !
<Moderator note: moved from a technical forum>
If one gear has X teeth and the other Y teeth, Y>X, and we start at an aligned pair, stepping to the next tooth of each in the same direction discovers a separation of ##2\pi/X-2\pi/Y##.
Repeating N times, the separation grows to ##N(2\pi/X-2\pi/Y)##, though at some point this will exceed ##|2N\pi/X-2(N+1)\pi/Y|##.
If this brings us to the randomly chosen pair of near-adjacent teeth, with a separation of ##\theta##, then ##N=\frac{\theta}{(2\pi/X-2\pi/Y)}##.
You can obtain a similar expression for the other case. The challenge then, if I understand the task, is to find the lower of the two values for N.
FAQ: Finding coincident angle between 2 equally spaced sets
What does "coincident angle" mean in the context of two equally spaced sets?
A coincident angle refers to an angle that appears at the same position in two different sets of angles. When two sets are equally spaced, each set forms a sequence of angles. A coincident angle is one where the angle in one set matches the angle in the other set at the same position.
How do you determine if two equally spaced sets have a coincident angle?
To determine if two equally spaced sets have a coincident angle, you compare the angles at each position in the two sets. If any angle in the first set matches the corresponding angle in the second set, then that angle is a coincident angle.
What mathematical methods are used to find coincident angles between two sets?
Mathematical methods to find coincident angles include using modular arithmetic to handle the periodic nature of angles, and comparing each angle in one set to each angle in the other set. For equally spaced sets, this often involves calculating the angles and checking for equivalence modulo 360 degrees (or 2π radians).
Can you provide an example of finding a coincident angle between two equally spaced sets?
Sure! Suppose we have two sets of equally spaced angles. Set A has angles 0°, 90°, 180°, and 270°. Set B has angles 45°, 135°, 225°, and 315°. By comparing each angle in Set A with each angle in Set B, we see that there are no coincident angles because none of the angles in Set A match any angle in Set B.
Why is it important to find coincident angles between two equally spaced sets?
Finding coincident angles between two equally spaced sets is important in various scientific and engineering applications, such as signal processing, synchronization of periodic systems, and the study of wave interference patterns. Identifying coincident angles can help in understanding the alignment and phase relationships between different periodic phenomena.
