AdkinsJr
- 150
An inclined plane with 20.0 degree angle has a spring with k=500 N/m at the bottom of the incline. A block of mass m=2.5kg is placed on the plane at a distance d=.300m from the spring. From this position, the block is projected downward toward the spring with speed v=0.750 m/s. By what distance is the spring compressed when the block momentarily comes to rest.
(1)[tex]x(t)=v_ot+\frac{1}{2}at^2[/tex]
(2) [tex]V(t)=v_o+gsin(\theta)t[/tex]
I think that the potential energy stored in the spring will be equal to the kinetic energy of the block at the equilibrium point.
(3)[tex]\frac{1}{2}mv_f^2=\frac{1}{2}kx_f^2[/tex]
With the x-axis parallel to the incline, the acceleration is cause by the component [tex]F_{gx}=gsin(\theta)[/tex]
I want to find the velocity using (2), so I need to find the time:
[tex]d=v_ot+\frac{1}{2}at^2[/tex]
[tex]t=\frac{-v_o \pm \sqrt{v_o^2+2dgsin(\theta)}}{gsin(\theta)}[/tex]
I find t=.102s. Puting this in the velocity function gave v(.102s)=1.09m/s. Finally, I put this into [tex]x_f=\sqrt{mv_o^2k^{-1}}[/tex] to obtain about .077 m. In the book they give .131m. I can't figure out where I went wrong.
