Finding conditional and joint probabilities from a table of data
In summary, the conversation discusses a function for a Markov Chain simulation and uses a 5-step simulation repeated 10 times as an example. The values of various probabilities are then discussed, including P(X1=1|X0=1), P(X2=1|X0=1), P(X5=2|X2=1), P(X1=1,X3=1), P(X5=2|X0=1,X2=1), and E(X2). The use of 'mean' in determining these probabilities is questioned and it is suggested to use the 'length' function instead.
user366312
TL;DR Summary
Finding conditional and joint probabilities from a table of data generated by Markov Chain simulation.
Let,
Code:
    alpha <- c(1, 1) / 2
    mat <- matrix(c(1 / 2, 0, 1 / 2, 1), nrow = 2, ncol = 2)
    chainSim <- function(alpha, mat, n)
      out <- numeric(n)
      out[1] <- sample(1:2, 1, prob = alpha)
      for(i in 2:n)
        out[i] <- sample(1:2, 1, prob = mat[out[i - 1], ])
      out
Suppose the following is the result of a 5-step Markov Chain simulation repeated 10 times:
Code:
> sim
     [,1] [,2] [,3] [,4] [,5] [,6] [,7] [,8] [,9] [,10]
[1,]    2    1    1    2    2    2    1    1    1     2
[2,]    2    1    2    2    2    2    2    1    1     2
[3,]    2    1    2    2    2    2    2    1    2     2
[4,]    2    2    2    2    2    2    2    1    2     2
[5,]    2    2    2    2    2    2    2    2    2     2
[6,]    2    2    2    2    2    2    2    2    2     2
What would be the values of the following?
  1. P(X1=1|X0=1)P(X1=1|X0=1)
  2. P(X2=1|X0=1)P(X2=1|X0=1)
  3. P(X5=2|X2=1)P(X5=2|X2=1)
  4. P(X1=1,X3=1)P(X1=1,X3=1)
  5. P(X5=2|X0=1,X2=1)P(X5=2|X0=1,X2=1)
  6. E(X2)E(X2)
I tried them as follows:
  1. mean(sim[2, sim[1, ] == 1] == 1)
  2. mean(sim[3, sim[1, ] == 1] == 1)
  3. mean(sim[6, sim[3, ] == 1] == 2)
  4. mean(sim[4, ] == 1 && sim[2, ]== 1)
  5. ?
  6. c(1,2) * mean(sim[2, ])
What would be the solution of (5)?
Am I correct withe the rest?
Technology news on Phys.org
Are you getting meaningful probabilities between 0 and 1 from your code?
I guess that I wasn't clear in a similar thread of yours Post #8 of similar thread
I think that your use of 'mean' is wrong here. It will give you the average of a lot of values of 1 and 2, which will be over 1. That can not be a probability. You must count the number of entries, not their values. You can do that by using the 'length' function as I showed in Post #8 of the other thread.
PS. I just noticed that this thread is several days old, so my answer here might already be known and understood by the OP.
Related to Finding conditional and joint probabilities from a table of data
1. What is the difference between conditional and joint probabilities?
Conditional probabilities refer to the likelihood of an event occurring given that another event has already occurred. On the other hand, joint probabilities refer to the likelihood of two or more events occurring together.
2. How can I find conditional probabilities from a table of data?
To find conditional probabilities from a table of data, you will need to identify the relevant row and column for the events you are interested in. Then, divide the cell that represents the intersection of those events by the total number of outcomes in the row or column.
3. How do I calculate joint probabilities from a table of data?
To calculate joint probabilities from a table of data, you will need to identify the cell that represents the intersection of the events you are interested in. Then, divide that cell by the total number of outcomes in the entire table.
4. What does the sum of all conditional probabilities equal to?
The sum of all conditional probabilities equals 1. This is because the conditional probabilities for all possible outcomes must add up to 100%.
5. Can conditional and joint probabilities be calculated for more than two events?
Yes, conditional and joint probabilities can be calculated for any number of events. However, as the number of events increases, the calculations become more complex and may require the use of more advanced statistical methods.
  • General Math
