Finding Continuous Values of $\frac{e^{sinx}}{4 - \sqrt{x^2 - 9}}$
In summary, the function is continuous for all values of x except for $x=\pm\sqrt{7}$. This is because the function becomes undefined when $4-\sqrt{x^2-9}=0$, which happens when $x=\pm\sqrt{7}$. Therefore, the function is not valid at these values of x. However, the reasoning for finding these values was incorrect as it did not consider the cases where the radicand is negative, leading to the incorrect conclusion that the function is not valid for $x=\pm\sqrt{7}$.
tmt1
234
I have this function
$$\frac{e^{sinx}}{4 - \sqrt{x^2 - 9}}$$
And I need to find all the values for which this function is continuous.
So I do
$$4 - \sqrt{x^2 - 9} \ne 0$$
$$ \sqrt{x^2 - 9} \ne 4 $$
$$ x^2 - 9 \ne 16 $$
$$ x^2 \ne 7 $$
And therefore, the function is not valid where
$$ x \ne +/- \sqrt{7} $$
However, this appears to be completely wrong. Why is my reasoning wrong?
Mathematics news on Phys.org
First, I would look at:
\(\displaystyle x^2-9\ge0\)
This gives us:
\(\displaystyle (-\infty,-3]\,\cup\,[3,\infty)\)
Next, look at
\(\displaystyle \sqrt{x^2-9}\ne4\)
\(\displaystyle x^2\ne25\)
\(\displaystyle |x|\ne5\)
\(\displaystyle (-\infty,-5)\,\cup\,(-5,5)\,\cup\,(5,\infty)\)
And so, we find:
\(\displaystyle (-\infty,-5)\,\cup\,(-5,-3]\,\cup\,[3,5)\,\cup\,(5,\infty)\)
This gives us:
Next, look at
And so, we find:
So what I had was correct but not comprehensive?
No, you took:
\(\displaystyle x^2-9\ne16\)
And added 9 to the left side while subtracting 9 from the right side. You also did not require the radicand to be non-negative. :)
So I do
$$ x^2 \ne 7 $$
No, if $x^2- 9\ne 16$ then $x^2= x^2- 9+ 9= 16+ 9= 25$, not 16- 9= 7.
FAQ: Finding Continuous Values of $\frac{e^{sinx}}{4 - \sqrt{x^2 - 9}}$
How do I find the continuous values of the given function?
To find the continuous values of the function, we first need to determine the values of x that will make the denominator equal to 0. In this case, the denominator will equal 0 when x = 3 or x = -3. These values must be excluded from the domain of the function to ensure continuity. We can then evaluate the function for all other values of x.
What is the domain of this function?
The domain of the given function is all real numbers except for x = 3 and x = -3. These values must be excluded to ensure continuity.
Can the given function have any vertical asymptotes?
Yes, the given function can have vertical asymptotes at x = 3 and x = -3. These are the values of x that make the denominator of the function equal to 0, causing the function to approach infinity.
How does the value of e affect the continuity of the function?
The value of e does not affect the continuity of the function. It simply acts as a coefficient in the numerator and does not change the behavior of the function at x = 3 or x = -3, where the continuity is affected by the denominator.
Can we use the graph of the function to determine the continuous values?
Yes, we can use the graph of the function to determine the continuous values. The graph will show us any vertical asymptotes at x = 3 and x = -3, which must be excluded from the domain of the function. We can then evaluate the function for all other values of x to find the continuous values.
