Finding Coordinates of Intersection in Parametric Forms
In summary, the individual is seeking help with understanding a couple of online questions related to parametric forms and parallel planes. They have posted screenshots of their progress and are specifically struggling with finding the value of t in the equation x-5=y-3=\dfrac{z}{2}=t and using a point to find the attitude number D in the equation 2x-2y+2z=D. They request for further explanation and assistance.
TheFallen018
52
Hey,
I have a couple of questions I've been doing online which have left me a little puzzled. The first one, I'm not really sure how to go about. I think a lot of that comes down to having not had a lot of experience with parametric forms.
I'll just post screenshots of where I'm up to on them, as they'll probably explain better where I'm up to.This is the one I'm having the most trouble with
This one, I've got most of the questions, but the last one is leaving me a little confused.
Any help would be amazing. Thanks :)
Mathematics news on Phys.org
\(\displaystyle x-5=y-3=\dfrac{z}{2}=t\). Use the equation of the plane to get \(\displaystyle t\).
Parallel planes have the same attitude numbers. So \(\displaystyle 2x-2y+2z=D\). Use the point to get \(\displaystyle D\).
Hey man, I appreciate the help. I guess I'm still not very familiar with this sort of stuff. Would you be able to expand on that a little? Cheers
\(\displaystyle x-5=t\), so \(\displaystyle x=\) ? Do the same for \(\displaystyle y\) and \(\displaystyle z\).
FAQ: Finding Coordinates of Intersection in Parametric Forms
What are coordinates of intersection?
Coordinates of intersection refer to the point or points where two lines, curves, or surfaces intersect or cross each other. These coordinates are represented by numerical values that indicate the location of the intersection on a coordinate plane.
How do you find the coordinates of intersection?
The coordinates of intersection can be found by solving a system of equations. For two lines, you can use the substitution or elimination method to find the coordinates. For curves or surfaces, you may need to use calculus to find the points of intersection.
Can the coordinates of intersection be negative?
Yes, the coordinates of intersection can be negative. This depends on the orientation and position of the intersecting lines, curves, or surfaces on the coordinate plane. Negative coordinates simply indicate that the point is located on the opposite side of the origin.
What if there are no coordinates of intersection?
If the lines, curves, or surfaces do not intersect, then there are no coordinates of intersection. This means that the equations of the lines or curves do not have a solution, and there is no point where they cross each other.
How are coordinates of intersection used in real life?
Coordinates of intersection are used in various fields such as engineering, physics, and geography. They can be used to determine the location of a point or object, calculate distances and angles, and solve problems involving multiple variables. They are also used in navigation systems, mapping, and GPS technology.
