MHB Finding Coordinates on a circle with time/speed
  • Thread starter Thread starter bsmithysmith
    Circle Coordinates
Marla runs clockwise on a circular track with a radius of approximately 21.96 meters, completing a lap in 46 seconds at a speed of 3 meters per second. Her starting coordinates are determined at the origin, with the northernmost point on the positive y-axis. The angular speed is calculated as π/23 radians per second, and the parametric equations for her position are established as x = (69/π)cos((47/46)π - (π/23)t) and y = (69/π)sin((47/46)π - (π/23)t). This discussion emphasizes the importance of understanding angular and linear speeds in circular motion to accurately determine coordinates over time.
bsmithysmith
Marla is running clockwise around a circular track. She runs at a constant speed of 3 meters per second. She takes 46 seconds to complete one lap of the track. From her starting point, it takes her 12 seconds to reach the northernmost point of the track. Impose a coordinate system with the center of the track at the origin, and the northernmost point on the positive y-axis. [UW]
a) Give Marla’s coordinates at her starting point.
b) Give Marla’s coordinates when she has been running for 10 seconds.
c) Give Marla’s coordinates when she has been running for 901.3 seconds.
So from what I understand, it's 3 meters/second and it takes 46 seconds to complete a lap, so $$46*3 = 138 meters$$ and then it's a circle, so 1 revolution is $$138/2Pi$$, giving the radius as approximately 21.96. From there, I have no idea what to do. I'm thinking angular speed $$(w = distance/time)$$ and linear speed $$(v = arclength/time)$$ although I think the linear speed is given as 3 meters/second, so angular speed is $$w = (21.96*theta)/seconds$$. The teacher did this in class but sadly his back was towards me the entire time so I got nothing from class that day. (Crying)
Mathematics news on Phys.org
Like you, the first thing I would do is find the radius of the track:
$$3\cdot46=2\pi r\implies r=\frac{69}{\pi}$$
I would then consider a parametric description of her position on the track. A parametric description of a circle of radius $r$ is:
$$x=r\cos\left(\theta_0+\omega t \right)$$
$$y=r\sin\left(\theta_0+\omega t \right)$$
Since Marla is running in a clockwise direction, we want to negate the parameter $t$. Also, we are told the period in seconds is 46, hence:
$$\omega=\frac{2\pi}{46}=\frac{\pi}{23}$$
So now we have:
$$x=r\cos\left(\theta_0-\frac{\pi}{23}t \right)$$
$$y=r\sin\left(\theta_0-\frac{\pi}{23}t \right)$$
Now, we need to determine the initial angle $\theta_0$. We are tole she is 12 seconds from:
$$\theta=\frac{\pi}{2}$$
$$\theta_0-\frac{12\pi}{23}=\frac{\pi}{2}$$
$$\theta_0=\frac{\pi}{2}+\frac{12\pi}{23}=\frac{47}{46}\pi$$
And so we have:
$$x=r\cos\left(\frac{47}{46}\pi-\frac{\pi}{23}t \right)$$
$$y=r\sin\left(\frac{47}{46}\pi-\frac{\pi}{23}t \right)$$
Using the value we found for $r$ and rewriting the arguments for the trig. functions by factoring, we may state:
$$x=\frac{69}{\pi}\cos\left(\frac{\pi}{46}\left(47-2t \right) \right)$$
$$y=\frac{69}{\pi}\sin\left(\frac{\pi}{46}\left(47-2t \right) \right)$$
This part was confusing. The theta looks like it has a zero subscript and the omega, which is theta/time, is multiplied by time again? Sorry to ask a lot of questions; I'd really like to understand the problem more.
$\theta_0$ represents the initial angle (when $t=0$) and $\omega$ represents the angular speed in radians per second. It determines the period of the parametric functions. If $T$ is the given period, then we know:
$$\omega=\frac{2\pi}{T}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
