Finding Cost of Cylinder with Constant Radius V
  • Thread starter robrob
  • Tags
    Shape
In summary: Your Name] In summary, the conversation discusses the process of proving a defining equation for the cost of making a cylinder of constant radius with a given volume. The equation involves variables such as height (h), radius (r), and cost factor (k). The suggested method to solve the problem is to use the given equations to express h in terms of r and V and then substitute the value of h in the defining equation. Other suggestions include seeking help from instructors or online resources.
robrob
How do I show that when I have C = 4√(3)r^2 + 2π(r)h + k(4π(r) + h), the cost C to make a cylinder of constant radius V gives the following defining equation: (∛(V))/k = (∛(π(h)/r)) x (2π - h/r)/π(h/r) - 4√(3)
k is the reciprocal of the length that can be joined for the cost of one unit area of metal.
((h/r) = 8/π ≈ 2.55 is the minimized amount of metal used
I've tried substituting h = 1000/(πr^2) and then found the derivative with respect to r but it doesn't prove the equation above.
We haven't learn partial derivatives yet, so is there any other way to solve this?
Thank you for your question. I would like to provide you with some guidance on how to approach this problem.
Firstly, it is important to understand the given equations and variables. The equation C = 4√(3)r^2 + 2π(r)h + k(4π(r) + h) represents the total cost (C) to make a cylinder of constant radius (r) with a given height (h) and a constant cost factor (k). The variable V represents the volume of the cylinder, and k is the reciprocal of the length that can be joined for the cost of one unit area of metal.
To prove the given defining equation, we need to show that when we substitute the values of h and r from the homework equations ((h/r) = 8/π and (∛(V))/k = (∛(π(h)/r)) x (2π - h/r)/π(h/r) - 4√(3)), we get the same result on both sides of the equation.
One way to approach this problem is by using the given equations to express h in terms of r and V. Then, substitute this value of h in the defining equation and simplify it to get the same result on both sides. I suggest you try this method and see if it helps you prove the equation.
If you are still unable to solve the problem, you can try reaching out to your instructor or classmates for help. Additionally, you can also consult some online resources or textbooks for guidance on solving similar problems.
I hope this helps. Good luck with your assignment!
Related to Finding Cost of Cylinder with Constant Radius V
1. What is the formula for finding the cost of a cylinder with a constant radius and volume?
The formula for finding the cost of a cylinder with a constant radius and volume is C = 2πrL, where C is the cost, π is the mathematical constant pi, r is the radius, and L is the length or height of the cylinder.
2. How do you determine the radius and volume of a cylinder?
The radius of a cylinder can be measured by dividing the diameter by 2. The volume of a cylinder can be calculated by using the formula V = πr²L, where V is the volume, π is the mathematical constant pi, r is the radius, and L is the length or height of the cylinder.
3. Can the cost of a cylinder with a constant radius and volume change?
Yes, the cost of a cylinder with a constant radius and volume can change depending on the material used and any additional costs such as labor or shipping.
4. How does the length or height of a cylinder affect its cost?
The length or height of a cylinder has a direct impact on its cost. The longer or taller the cylinder, the more material is needed to create it, which can increase the cost. Additionally, if the length or height of a cylinder is increased, the volume also increases, which can further affect the cost.
5. Are there any other factors besides radius and volume that can affect the cost of a cylinder?
Yes, there are other factors that can affect the cost of a cylinder, such as the material used, labor costs, and any additional fees or taxes. The shape of the cylinder may also play a role in the cost, as more complex shapes may require more time and resources to create.
