MHB Finding Depth of Perfect & Complete Binary Trees
To find the depth of a perfect binary tree, the proposed algorithm suggests traversing the leftmost nodes until a null pointer is reached, incrementing a depth counter. This approach is valid for perfect binary trees, where all leaves are at the same depth. For complete binary trees, which may not have all leaves at the same depth, the same algorithm can be applied, but it may not yield accurate results if the tree structure varies. A full traversal is recommended for trees that do not guarantee uniform leaf depth. There is a clarification needed regarding the traversal method, specifically whether to use the left child pointer instead of the next pointer.
evinda
MHB
Hi! (Wave)
How can we find the depth of a perfect binary tree and how of a complete one? (Thinking)
Since a perfect binary tree is a full binary tree, at which the leaves have the same depth, I thought that we can find the depth, by just looking at the leftmost nodes, like that:
Code:
Algorithm(NODE *tree){
pointer p=tree;
int depth=0;
while (p!=NULL){
         p=p->next;
         depth++;
return depth;
A complete binary tree of height $h$ consists of a perfect binary tree of height $h-1$, at which, one or more leaves with height $h$, have been added.
The leaves have been placed at the leftmost positions of the tree.
I thought that we could use again the above algorithm.
Am I right or have I done someething wrong? (Thinking)
Technology news on Phys.org
evinda said:
Hi! (Wave)
Code:
pointer p=tree;
int depth=0;
while (p!=NULL){
         p=p->next;
         depth++;
return depth;
If the tree truly does have all its leaves at the same depth, this algorithm should work fine.
On the other hand, if you're not guaranteed a tree where all leaves are at the same depth, I don't see any way of computing the depth of the tree other than a full traversal.
[EDIT] You did mean
Code:
p = p->lc
, right?
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
