Finding Depth of Water Loss Using Surface Area
In summary, a city with 30,000 residents and an average daily water usage of 1100 liters per family would result in a total of 3,011,250,000 liters of water being used per year. If the city's only source of water is a lake that covers 40 square kilometers, and the sides of the lake are assumed to be vertical, the lake would lose approximately 7.53 cm of depth per year. However, if the lake has sloped sides, the rate of depth loss could potentially be higher due to a decrease in surface area as the level drops.
Kova Nova
A city with 30,000 residents lies next a lake which is their only source of water. The average family of four in this city uses 1100 liters of water per day. Neglecting rain and evaporation, how much depth would the lake lose per year if it covered 40 square kilometers?
unknown
To begin with, I of course divided the 30,000 residents by 4 to gain 7,500 families living in the city. I then multiplied the number of families by 1,100 liters and got 8,250,000 L/day and then multiplied that product by 365 days to get 3,011,250,000 L/year being used.
I know that 1 decimeter^3 is equal to 1 liter and that there are 1,000,000,000,000 liters in a kilometer^3. So I attempted to raise (1x10^12 dm^3) to the power of 2/3 which in turn gave me 1x10^8 dm^2. I then converted 1x10^8 dm^2 to 1 km^2 as they are one in the same and then I divided 1 km^2 by 40 km^2 and then raised that fraction to the power of 1/2 thus giving me 0.15811 km or 158.11 m of water being lost per year.
I know at least half of this is wrong, (I just realized I didn't even implement the amount of L/year being used), I tried to assume a certain depth as well but that led me nowhere either. If someone could just push me in the right direction I would be very thankful.
First, it asks how much depth will it lose... But it does not specify a time period. So either you missed typing that into the problem statement, or just specify a time period.
Next, try this. Figure how many square meters the lake is. This is area or Length2. How can you get from volume (Length3) to depth (Length1), by using area (Length2)? Hint: you do not have to raise to powers of 2/3 or 1/2.
Thank you very much, I got 7.53 cm lost/year. I'm not sure if it's correct but it makes a lot more sense than what I had before.
Maybe I missed the per year, the first time I read it.
I also calculated 7.53 cm per year.
Kova Nova said:
... then I divided 1 km^2 by 40 km^2 and then raised that fraction to the power of 1/2 thus giving me 0.15811 km or 158.11 m
Notice what you did here: taking (1 km2) / (40 km2) causes the km2 to cancel, giving you a dimensionless number. So that should tell you that is not the right approach.
unknown
Are the sides of the lake vertical, or are they sloped? The volume vs. depth computation is different if the lake is a cylindrical hole in the ground, than if it is a cone-shaped depression, for example.
Likes scottdave
I was thinking on similar track, but since the OP did not specify, I tried vertical walls first. Ballpark calculations in my head, I arrived at 0.2 mm per day, which is close to what the OP came up with.
Isn't that second order? I.e. it just means the rate of change would diminish year on year.
If it does slope as most lakes would (at least for some of the shoreline), then as level drops, the surface area will decrease. Then for the same amount of volume extracted, the water level will drop more.
Yes, I should have gone back to read the question exactly. I was thinking of evaporation. But my point is that the the effect of the slope is second order, so can be ignored.
Yes, for one day's withdrawal that is true. But the question asked for an annual figure, so we have 365 small effects.
FAQ: Finding Depth of Water Loss Using Surface Area
1. How is the depth of water loss calculated using surface area?
The depth of water loss can be calculated by dividing the volume of water lost by the surface area of the water body. This gives us the average depth of water loss across the entire surface area.
2. What tools or methods are used to measure surface area for calculating water loss?
There are several tools and methods that can be used to measure surface area for calculating water loss. Some common methods include using aerial photography, satellite imagery, and ground surveys with specialized equipment such as LiDAR or sonar.
3. Can the depth of water loss be accurately determined using surface area calculations?
While surface area calculations can provide a good estimate of the average depth of water loss, it is important to note that they may not account for localized variations in depth or other factors that may affect water levels. Other methods, such as direct measurement or modeling, may be needed for a more accurate determination.
4. What are some potential sources of error when using surface area to calculate water loss?
There are several potential sources of error when using surface area to calculate water loss. These can include variations in surface area due to changes in water level or shoreline erosion, inaccuracies in measurement methods, and limitations in the data used for calculations.
5. How can the information obtained from finding depth of water loss using surface area be used?
The information obtained from calculating water loss using surface area can be used to track changes in water levels over time, identify areas with significant water loss, and inform management and conservation efforts. It can also help to understand the overall health and sustainability of a water body.
