MHB Finding diameter of a sphere, have density and mass
To find the diameter of a balloon made from a material with a density of 0.310 kg/m² and a mass of 2756 kg, the density refers to the surface area rather than volume. The correct approach involves calculating the surface area using the formula A = Mass/Density, yielding an area of approximately 8890.323 m². From this area, the radius is derived using the formula r = √(A/(4π)), resulting in a radius of about 26.598 m. Consequently, the diameter of the balloon is approximately 53.20 m, highlighting the importance of correctly interpreting density in relation to surface area.
polskon
A balloon is made from material that has a density of 0.310 kg/m2. If the balloon has a mass of 2756 kg and if it is assumed that the balloon is a perfect sphere, what is the diameter of the balloon? Keep the proper number of significant digits.
Mass = Density x Volume
2756kg = 0.310kg/m^2 x Volume
2756kg / 0.310 kg/2 = Volume
Volume = 8890.322581 m^3
8890.322581 m^3 = 4/3(pi)r^3
3(sq)8890.322581 m^3 / (4/3(pi)) = r
r = 12.85117892 m
D = 25.70235784 m
Diameter to 3 significant digits = 25.7 m
Answer is wrong, what is the problem with my answer?
Mathematics news on Phys.org
r = 12.85117892 m
D = 25.70235784 m
1. I assume that the text of the question is correct. Then the balloon is hollow and not solid! The densitiy refers to the envelope of the balloon.
Let A denotes the surface area of the balloon. Then
$ A \cdot 0.310\ \tfrac{kg}{m^2} = 2756\ kg $
That means $ a = 8890.323\ m^2 $
2. The surface of a sphere is calculated by:
$ A = 4 \cdot \pi \cdot r^2~\implies~r=\sqrt{\frac{A}{4 \pi}} $
3. I've got $ r \approx 26.598 \ m $
https://www.physicsforums.com/threa...meter-of-a-sphere-using-a-screw-gauge.991087/
Hello, polskon!
I agree with earboth . . .
Note that the density is given as 0.310 kilograms per square meter.
We are dealing with the surface area of the spherical balloon, not its volume.
. . (And the thickness of the balloon is considered negligible.)
The area of a sphere is: .A = 4πr2
Mass = Density x Area
. . 2756 .= .0.31 x A . . → . . A .= .2756/0.31
Then: .4πr2 .= .2756/0.31 . . → . . r2 .= .2756/1.24π .= .707.4693922
. . . . . r .= .26.59829670 Therefore: .Diameter .≈ .53.20 m
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
