MHB Finding Eigenvalues for Different r Values
  • Thread starter Thread starter Dustinsfl
    Eigenvalues
Dustinsfl
\mathcal{J} = \begin{pmatrix}
-\sigma & \sigma & 0\\
1 & -1 & -\sqrt{b(r - 1)}\\
\sqrt{b(r - 1)} & \sqrt{b(r - 1)} & - b
\end{pmatrix}
From a quick try and error, I was able to find that when $r = 1.3456171$ we will have 3 negative eigenvalues.
But when $r = 1.3456172$, there will be a complex-conjugate pair of eigenvalues.
Is there a mathematically more elegant way to determine this r value?
$b = \frac{8}{3}$ and $\sigma = 10$
\end{pmatrix}
This is an interesting problem. The eigenvalue equation is $\det(\mathcal{J} - \lambda I) = 0$, which simplifies to $$\lambda^3 + (b+\sigma+1)\lambda^2 + b(r+\sigma)\lambda + 2b\sigma(r-1) = 0.\qquad(1)$$ At the critical value of $r$ (the one where the bifurcation occurs, from three real roots to a complex conjugate pair), the eigenvalue equation will have a repeated root. That root will also be a root of the derived equation. So differentiate the eigenvalue equation to get $$3\lambda^2 +2(b+\sigma+1)\lambda + b(r+\sigma) = 0.\qquad(2)$$ Solve those equations together, to find that $$\lambda = \frac{18b\sigma(r-1) - b(b+\sigma+1)(r+\sigma)}{2(b+\sigma+1)^2 -6b(r+\sigma)}.$$ The next stage is to substitute that value of $\lambda$ into equation (2), to get a cubic equation for $r$. If you have stamina and patience enough to do that, you should find that, for the given values of $b$ and $\sigma$, one of the solutions is $r = 1.345617...$. (Rather you than me, though. (Yawn) )
How did you get this lambda? I solved for the quadratic and got something different. I also set the quadratic and cubic equal and then solved for lambda but didn't arrive at this lambda either.
Starting from $$\lambda^3 + (b+\sigma+1)\lambda^2 + b(r+\sigma)\lambda + 2b\sigma(r-1) = 0\qquad(1)$$ and $$3\lambda^2 +2(b+\sigma+1)\lambda + b(r+\sigma) = 0,\qquad(2)$$ I multiplied (1) by 3, and (2) by $\lambda$, and subtracted, getting $$(b+\sigma+1)\lambda^2 + b(r+\sigma)\lambda + 6b\sigma(r-1) = 0.\qquad(3)$$ I then multiplied (2) by $(b+\sigma+1)$, and (3) by 3, and again subtracted, to get the equation $$\lambda = \frac{18b\sigma(r-1) - b(b+\sigma+1)(r+\sigma)}{2(b+\sigma+1)^2 -6b(r+\sigma)}.$$
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
