Finding electric field at the center of a polarized cylinder
In summary, a uniformly polarized cylinder with height h and radius 10h has surface bound charges of P on the upper surface and -P on the lower surface. The electric field at the center of the cylinder can be found by taking the gradient of the potential between the two discs with surface charge densities of equal magnitude and opposite signs. The potential at the center will be zero but the function will not vanish, allowing for the calculation of the electric field.
phys-student
32
Consider a uniformly polarized electret in the shape of a cylinder with height h and radius 10h. The polarization in the dielectric is P, parallel to the cylinder axis.
a) calculate surface and volume bound charges
b) calculate the electric field at the center of the cylinder. Since the radius is large compared to the height, you may neglect edge effects.
σb = P⋅n
ρb = - ∇⋅P
I've already worked out part a and found there's a surface bound charge of P on the upper surface, and -P on the lower surface. I tried to do part b by finding the potential in the middle of the cylinder due to the top and bottom surface separately, then adding them together to get the total potential, then taking the gradient to find the electric field. When I tried to do this the potential from the top and bottom surfaces cancel giving me 0 total potential and thus no electric field, but I know this doesn't make any sense since there should be field lines going from the positive surface to the negative surface. Can someone help point me in the right direction?
Zero potential does not imply zero field, is that not correct? Why?
I was trying to use the equation:
E = -∇V
To find the electric field. If the potential is 0 then the gradient will also be 0, this is why I thought that no potential means there is no electric field
What is the interpretation of the term gradient?
Just the normal definition of the gradient. Derivative w.r.t. x times x-hat plus derivative w.r.t. y times y-hat plus derivative w.r.t. z times z-hat
https://en.wikipedia.org/wiki/Gradient
So what does the value of a function at a point have to do with its gradient?
This is the approach that I used:
I wanted to find an expression for the potential due to the top and bottom discs separately, then sum the 2 expressions to find the total potential, once I have an equation for the total potential I would take the gradient of it to find the electric field. However, when I try to sum the 2 expressions I am left with 0 since the geometry of the discs is the same but the charges are opposite. If there is something wrong with the approach I'm using please let me know
What is the equation for the potential that you are using?
I used the equation for finding potential due to a surface charge:
V = (1/4*pi*ε) ∫ (σ/r2) da
Where ε is the vacuum permittivity constant, σ is the surface charge density, and r is the distance between the disc and the field point.
Evaluating this expression for the top disc I get:
Vtop = (σ/2*ε)*[(r2 + z2)0.5 - z]
Where r is the radius of the disc. When I do the same thing for the bottom disc I get the same expression except with -σ instead of σ. So when I try to sum them I get 0.
Ah ha. You can't use the same general expression for the potential for both sides of the disk as in general you will be closer to one surface compared to the other..
dVtop ~ 1/ (r2 + z2)½ while dVbot ~ 1/ (r2+(t-z)2)½
where r is the distance from the center to the position of an elemental area da, z is the distance from the top and t is the thickness of the disk.
Sorry i must not have made the problem clear enough... I am looking for the potential in the center of a uniformly polarized cylinder. Since the polarization causes surface charges to only exist on the top and bottom surfaces, I was approximating the situation by looking for the potential between 2 discs with surface charge densities that are equal in magnitude but with opposite signs. The expression you've given me appears to be for the potential on either side of a disk with a finite thickness which is not what I'm looking for
You solve the problem for the general case i.e., the potential anywhere on the central axis, take the gradient of that equation then evaluate the result at the center of the cylinder. the electric field depend on how the potential varies on the central axis. You want to express the distance from the front and the back with the same variable ( say z). From the front it is z but from the back it is the thickness -z. the acutal potential at the midpoint will be zero by the function will not vanish so you can take the gradient of it. and get E.
Likes phys-student
Okay now I get what you're saying. Thanks for the help, just finished the problem now
FAQ: Finding electric field at the center of a polarized cylinder
1. What is a polarized cylinder?
A polarized cylinder is a cylindrical object that has been subjected to an external electric field, causing the positive and negative charges within the cylinder to become separated, resulting in a net electric dipole moment.
2. How is the electric field at the center of a polarized cylinder calculated?
The electric field at the center of a polarized cylinder can be calculated using the formula E = kP/r^3, where k is the Coulomb constant, P is the dipole moment of the cylinder, and r is the distance from the center of the cylinder.
3. What factors affect the strength of the electric field at the center of a polarized cylinder?
The strength of the electric field at the center of a polarized cylinder is affected by the magnitude of the dipole moment, the distance from the center of the cylinder, and the direction of the external electric field.
4. Can the electric field at the center of a polarized cylinder be zero?
Yes, the electric field at the center of a polarized cylinder can be zero if the magnitude of the dipole moment is zero or if the external electric field is parallel to the axis of the cylinder.
5. What are some real-life applications of finding the electric field at the center of a polarized cylinder?
Some real-life applications of finding the electric field at the center of a polarized cylinder include analyzing the behavior of molecules, studying the properties of materials, and designing electronic devices such as capacitors and sensors.
