MHB Finding equation of parabola with focus and directrix
  • Thread starter Thread starter hatelove
    Focus Parabola
To find the equation of the parabola with the given directrix y = -x + 2 and focus at (0,0), the vertex is determined to be at (0.5,0.5) using the midpoint formula. The standard form of the parabola is derived as (x - 0.5)² = 2√2(y - 0.5), which simplifies to y = (x² - x + (4√2 + 1)/4) / (2√2). However, there is confusion as the graph appears to intersect the directrix, which contradicts the definition that a parabola does not touch its directrix. The correct approach involves using the distance formula from the focus and the directrix, leading to the final equation (x + 2)² + (y + 2)² - 2xy - 12 = 0.
hatelove
Given directrix y = -x + 2 and focus (0,0), find the equation of the parabola
So I found the equation for the perpendicular line to the directrix in order to find the vertex, which I got the line y = x that is perpendicular to the directrix, then solved the system of equations to find the common intersection point, which was (1,1). I used the midpoint formula from the focus to the directrix, and got (0.5,0.5) (even though I know by intuition). So the vertex is at (0.5,0.5) since it is exactly in between the focus and directrix.
Using the form (x - \frac{1}{2})^{2} = 4p(y - \frac{1}{2}), I plugged in the vertex already. To find the value of 'p' I needed to use the distance formula for between either the focus and vertex, or the vertex and directrix which I know should be exactly the same. So I did: distance = \sqrt{(\frac{1}{2} - 0)^{2} + (\frac{1}{2} - 0)^{2}}
distance = \sqrt{(\frac{1}{4}) + (\frac{1}{4})}
distance = \sqrt{\frac{2}{4}}
distance = \frac{\sqrt{2}}{2}
So:
(x - \frac{1}{2})^{2} = 4(\frac{\sqrt{2}}{2})(y - \frac{1}{2})
(x - \frac{1}{2})^{2} = \frac{4\sqrt{2}}{2}(y - \frac{1}{2})
(x - \frac{1}{2})^{2} = 2\sqrt{2}(y - \frac{1}{2})
Put in standard form:
y = \frac{x^{2} - x + \frac{4\sqrt{2} + 1}{4}}{2\sqrt{2}}
I don't know if I've made any careless errors and I didn't want to rationalize the denominator and risk messing this up, but when I try to graph this, the graph of the parabola passes through the directrix...I thought it wasn't supposed to touch it at all?
Mathematics news on Phys.org
Hello, daigo!
given directrix .y \:=\:\text{-}x+2 and focus (0,0), find the equation of the parabola.
Sorry ... you started off wrong . . .
The directrix is a slanted line.
The parabola has been rotated.
The equation will have an xy-term.
The graph looks like this . . .
Code:
          o |
           2o
            | o
            |   o       .
            |     o   .
            |       o
      *     *     .   o
            |   *       o
            | .           o
      ------o------*--------o----
            |F              2 o
        .   |                   o
So I should not use the (x-h)^2 = 4p(y - k) form and there's a different equation to be used?
By the way, how did you create that ASCII graph? Surely it'd take too much of your time to draw it by hand
Hello, daigo!
Surely it'd take too much of your time to draw it by hand.
I created a procedure several years ago.
Since then I've explained it on a few other math-sites,
. . but never on this site.
Besides, that was a few years ago
. . and my mini-lessons are surely buried.
It is quite a bit of work, but I enjoy it:
. . the challenge, the planning, etc.
Obviously, I go into CODE mode.
First, I type this line: period-period-period-hyphen-hyphen-hyphen . . .
. . with a space between them.
Code:
Then I use COPY/PASTE to make, say, four such lines.
Code:
Then I use COPY/PASTE again to make a few more such sets.
Code:
Then I carefully insert other symbols,
. . replacing the hyphens.
Code:
Then I eliminate the unwanted symbols.
At the far right, I simply delete the hyphens.
At the left, I replace each hyphen with a space.
Code:
One of my favorites is a large circle.
Code:
I like to leave a margin at the left of the diagram.
That's the reason for the three periods.
Wow, you really do draw it manually! Surely there must be a way to code a small script where you input a formula and it draws out a graph maybe. Anyway, that's cool
So:
1. Use the definition of the parabola as the locus of points whose distance from a straight line and a fixed point are equal.
2. Let P(x ,y) denotes the point on the parabola. Then the distance from the focus (= origin) is
\displaystyle{d_1=\sqrt{x^2+y^2}}
3. The distance of a point Q(m, n) from the line Ax + By + C= 0 is
\displaystyle{D=\frac{Am+Bn+C}{\sqrt{A^2+B^2}}}
In your case the line has the equation: \displaystyle{x+y-2=0}
and A = 1 and B = 1 and C = -2
4. Now screw those bits and pieces together:
\displaystyle{\sqrt{x^2+y^2}=\frac{x+y-2}{\sqrt{1+1}}}
5. This equation describes the parabola. After a few steps you should come out with:
\displaystyle{(x+2)^2+(y+2)^2-2xy-12=0}
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
