Finding equations for electric field lines
In summary: You are looking for an equation to describe the electric field lines in a particular geometry. This is something that is difficult to do mathematically. You would need to solve for the electric field intensity at a certain point or arbitrarily pick a point and use Maxwell's equations to find the equation.
js2020
64
TL;DR Summary
I would like to find an equation for E-field potentiality lines
Hi,
I am interested in finding the equation for electric field equipotential lines. Ideally, it would be nice to have one equation that worked to find it for different geometries. Unfortunately, I don't think that exists. Assuming it does not exist, I think I would probably have to either solve for the electric field intensity at a certain point...or arbitrarily pick a value that I know exists (using Maxwell's equations?). Assuming I'm in 2D, I would then pick a different X (or Y) and set the equation equal to the previous defined electric field intensity. I would do this for a lot of different X,Y combinations and start to see a line. Is this correct? If so, would I then have to plot those points and just use something like Matlab's curve fitting function to find the equation? Or how would I approach this?
js2020 said:
Summary:: I would like to find an equation for E-field potentiality lines
Mapping electric fields mathematically is only possible for very simple geometry. The boundary conditions must be defined, but some can be infinite.
https://en.wikipedia.org/wiki/Electrostatics#Electric_field
Mapping electric fields arithmetically using FEM is easiest in two dimensions, and possible in 3 dimensions. Point charges have infinite gradients so must be represented by small areas. Again, the boundary conditions must be defined. But they cannot really be infinite.
In both processes, the shape of the conductors are defined as lines of equipotential.
https://en.wikipedia.org/wiki/Field_line#Construction
Likes eq1
This book is well worth finding;
Analysis and Computation of Electric and Magnetic Field Problems. Second Edition. 1973.
By K. J. Binns and P. J. Lawrenson. Publisher; Pergamon Press.
ISBN 0-08-016638-5
Also;
Title; Electric Field Analysis. 2015.
By; Sivaji Chakravorti. Publisher; CRC Press.
ISBN-13: 978-1-4822-3337-7 (eBook - PDF)
Likes eq1 and berkeman
Thanks for the book suggestions. I requested the first one and was able to download the second one through my library.
I understand how to do it using FEM. I was hoping to find the equation describe those lines somehow. I understand it would change based on the geometry though. Again, thanks for the book suggestions. I'll see if I can find a way there.
Likes berkeman
You are getting into the field of Orthogonal Transforms and Mapping.
They are useful for EM fields and fluid flow such as airfoils.
I'll see if I can read on orthogonal transforms and mapping in general then.
Just thinking about what I'm trying to do, I can see it being useful for airfoils too. I'm interested in finding out how to design high voltage electrodes. I've found some formulas for different profiles like rogowski, earnst, cheng, etc but I'm wondering how they got the equations in the first place.
I looked at their equations and I'm sure it's just because I'm new to this all together but I'm not sure how to even use those variables.
The geometry of orthogonal EM fields is fundamental.
For example, the evolution of Paul Neill's “N-type connector” into the BNC connector, occurred once an applied mathematician, Carl Concelman, understood the problem.
BNC = Bayonet Neill–Concelman. TNC = Threaded Neill–Concelman.
https://en.wikipedia.org/wiki/BNC_connector
But that is all in the past. Now for the future ...
Likes js2020
FAQ: Finding equations for electric field lines
What is an electric field line?
An electric field line is an imaginary line that represents the direction and strength of the electric field at various points in space. It is a visual tool used to understand and analyze the behavior of electric fields.
How do you find equations for electric field lines?
To find equations for electric field lines, you can use the equation E = kQ/r^2, where E is the electric field strength, k is the Coulomb's constant, Q is the charge creating the field, and r is the distance from the charge. You can also use the principle of superposition to find the total electric field at a point due to multiple charges.
What information do you need to find equations for electric field lines?
To find equations for electric field lines, you need to know the magnitude and location of the charges creating the field. You also need to know the distance from the charges to the point where you want to find the electric field strength.
What are some real-life applications of electric field lines?
Electric field lines have many real-life applications, such as in the design of electronic devices, the study of lightning and thunderstorms, and the analysis of electric fields in the human body. They are also used in the development of technologies like electrostatic precipitators and particle accelerators.
How can electric field lines help us understand the behavior of electric fields?
Electric field lines provide a visual representation of the direction and strength of electric fields. By analyzing the patterns of the field lines, we can understand how electric charges interact with each other and how electric fields affect the motion of charged particles. Electric field lines also help us visualize the concept of equipotential surfaces, which are surfaces where the electric potential is constant.
