Finding equations w/ two given points:
  • Thread starter AznBoi
  • Tags
    Points
In summary, the conversation discusses finding the equation for two given points, (-3,0) and (-.5,0). The individual's work shows the process of completing the square to find the equation y=(x+1.75)^2+11.9375. It is then pointed out that there are multiple functions that can pass through these two points.
AznBoi
471
Ok there are two give points and I need to find the equation:
My work:
y=(x+3)(x+.5)
y=x^2+.5x+3x+15
Completed the square:
-15= x^2+3.5x
-15=x^2+3.5x+3.0625
-11.9375=(x+1.75)^2
y= (x+1.75)^2+11.9375
What did I do wrong??
[tex] y = (x+3)(x+.5) = x^{2}+3.5x + 1.5[/tex]
you multiplied 3 by 5, instead of 3 by 0.5
ohhh lol thanks.
Why did you assume a quadratic function? Two points determine a straight line. The constant function y= 0 passes through (-3, 0), (-5, 0).
In fact there are an infinite number of functions whose graph pass through those two points.
Halls, he meant the zeros of the function. He is doing quadratic equations after all.
FAQ: Finding equations w/ two given points:
How do you find the equation of a line using two given points?
To find the equation of a line using two given points, you can use the slope-intercept formula (y = mx + b) or the point-slope formula (y - y1 = m(x - x1)). First, calculate the slope (m) by dividing the difference in y-coordinates by the difference in x-coordinates. Then, plug in the slope and one of the given points into either formula to find the y-intercept (b). Finally, write the equation in the desired form, y = mx + b or y - y1 = m(x - x1).
Can you find the equation of a line if one of the given points is the y-intercept?
Yes, if one of the given points is the y-intercept, then you can use the slope-intercept formula (y = mx + b) to find the equation of the line. Simply plug in the given y-intercept as the value for b and use the other given point to calculate the slope (m).
What is the difference between the slope-intercept formula and the point-slope formula?
The slope-intercept formula (y = mx + b) is used when you know the slope (m) and the y-intercept (b) of a line, while the point-slope formula (y - y1 = m(x - x1)) is used when you know the slope (m) and one point (x1, y1) on the line. Both formulas can be used to find the equation of a line, but the point-slope formula may be more useful when only one point is given.
Can you find the equation of a line if the two given points are the same?
No, if the two given points are the same, then there are infinitely many lines that can pass through those points. In this case, you cannot find a unique equation for the line. However, if you are given one point and the slope of the line, you can still find the equation using the point-slope formula.
Is it possible to find the equation of a vertical line using two given points?
No, it is not possible to find the equation of a vertical line using two given points. A vertical line has an undefined slope, so you cannot use the slope-intercept formula or the point-slope formula to find its equation. Instead, you can use the equation x = a, where a is the x-coordinate of any point on the line, to represent a vertical line.
