Finding equivalent mass moment of inertia for gear system
In summary: X_subscript still wrong, Sorry about that.In summary, the mass moment of inertia corresponding to theta_1 is equivalent to the sum of the kinetic energy of the two masses multiplied by the gear ratio.
immel
Two masses, having mass moments of inertia J1 and J2, are placed on rotating rigid shafts that are connected by gears. If the numbers of teeth on gears 1 and 2 are n1 and n2, respectively, find the equivalent mass moment of inertia corresponding to theta_1.
Kinetic energy of a rotating shaft = 1/2*J*theta_dot
J = 1/2*m*r^2
n1/n2 = theta_1/theta_2 ?
This is for my mechanical vibrations class for ME majors. I assume I need to relate theta_dot_1 to theta_dot_2 somehow. I am also not sure what to do with the number of teeth. It seems as though I may be able to do something with the gear ratio, but I don't know where to begin relating things. Please help!
hi immel! :smile:
(have a theta: θ and try using the X2 and X2 icons just above the Reply box :wink:)
don't you have cogs in your brain? :rolleyes:
the ratio of the number of turns equals the ratio of the number of teeth! :wink:
Thanks for the help tiny-tim.
So was I right with my assumption that n1/n2 = θ12 ?
I am confused about what variable I am solving for. In the problem statement "...find the equivalent mass moment of inertia corresponding to θ1." Does this mean I'm solving for θ1 or some product with the unit of mass*length2 (mass moment of inertia has these units)? J=1/2*m*r2 has units of mass*length2.
It's starting to look like I need to relate the kinetic energy equation and n1/n2 = θ12.
hi immel! :smile:
i think by "equivalent" it means that if you pretend that you can only see one cog, and it's rotating at angular speed θ1', then you want a formula L = Jequivθ1', where L is the angular momentum for the whole system, and Jequiv can then be called the equivalent (or effective) mass moment of inertia for the whole system :wink:
I've come up with a solution, but using the equivalent kinetic energy method.
With the relation n1/n2 = θ12 = θ1'/θ2' (is this valid?), I solved for θ2' = (θ1'*n2)/n1
I have KE1=1/2*J11'2 and KE2=1/2*J2*[(θ1'*n2)/n1]2
I then have KEsystem = KE1 + KE2 where KEsystem = 1/2*Jeq1'2
Canceling out the 1/2 and θ1'2 I was left with Jeq = J1 + J2*(n2/n1)2
Sooo, how far off am I?
oh, that's probably right then! :biggrin: (i haven't come across equivalent moment of inertia before :redface:)
Looks good! :smile:
Thanks tiny-tim! Much appreciated
I know this is about 2 years later but in case anyone comes across this looking for help I wanted to correct an error I noticed in the calculations. When making the relationship between number of teeth, [n][/1] and [n][/2] and angular velocity [θ'][/1] and [θ'][/2] they are inversely proportional. Namely, if [n][/1] < [n][/2] then [θ'][/1] > [θ'][/2]. If you think about it less teeth equals smaller diameter and when a constant torque is applied the smaller gear (and shaft coupled to it will spin faster than the gear with more teeth. Right? So the appropriate relations ship should between the two is:
[n][/1]/[n][/2]=[θ'][/2]/[θ'][/1]
NOTE: often both "n" and "N" are used in gear train calculations but refer to different things. "N" would be the RPMs of the gear and "n" equals the number of teeth of the gear. Adding diameter "d" onto the mix the following relationships all exist:
[d][/1]/[d][/2]=[n][/1]/[n][/2]=[N][/2]/[N][/1]=[θ'][/2]/[θ'][/1]
This is if, of course, the diameter and number of teeth are dirrectly dependent upon one another (which they are if your using gears in the real world)
Sorry about [x][/1] crap in the earlier post I guess I did the X_subscript wrong so I hope anyone reading it can get the drift
FAQ: Finding equivalent mass moment of inertia for gear system
What is the purpose of finding the equivalent mass moment of inertia for a gear system?
The equivalent mass moment of inertia for a gear system is used to simplify the analysis of rotational motion by representing the combined effect of multiple gears as a single, equivalent mass moment of inertia. This allows for easier calculation of the system's overall rotational motion.
How is the equivalent mass moment of inertia calculated for a gear system?
The equivalent mass moment of inertia for a gear system is calculated by summing the individual mass moments of inertia of each gear and adding a correction factor to account for the gear ratio. The formula is: equivalent mass moment of inertia = sum of individual mass moments of inertia + (gear ratio)^2 x (sum of individual mass moments of inertia).
Is the equivalent mass moment of inertia affected by the number of gears in the system?
Yes, the equivalent mass moment of inertia is affected by the number of gears in the system. The more gears there are in the system, the larger the equivalent mass moment of inertia will be.
Can the equivalent mass moment of inertia be negative?
No, the equivalent mass moment of inertia cannot be negative. It is a measure of an object's resistance to rotational motion and is always a positive value.
How does the equivalent mass moment of inertia affect the overall performance of a gear system?
The equivalent mass moment of inertia can affect the speed and torque of a gear system. A higher equivalent mass moment of inertia can result in slower acceleration and a lower maximum speed, while a lower equivalent mass moment of inertia can result in faster acceleration and a higher maximum speed. It is important to consider the equivalent mass moment of inertia when designing a gear system to ensure optimal performance.
