Finding Exact Value using Trig Identities and Complementary Angle Theorem
In summary, the conversation was about finding the exact value of $\cot(\frac{\pi}{2} - x)$ given that $\tan x = 10$. The solution was found using a trigonometric identity and the help was greatly appreciated.
Dundee3
Hey guys, I've been trying to wrap my mind around this problem but I've really come up short.
Any help would be amazing.
If tanX=10 Find the exact value of cot(pi/2 - x)
Mathematics news on Phys.org
Among the identities You find in...
List of trigonometric identities - Wikipedia, the free encyclopedia
... there is $\displaystyle \cot (\frac{\pi}{2} - x) = \tan x$...
Kind regards
$\chi$ $\sigma$
Brilliant. Simply brilliant.
Thank you!
FAQ: Finding Exact Value using Trig Identities and Complementary Angle Theorem
What is the Complementary Angle Theorem?
The Complementary Angle Theorem states that the sum of two complementary angles is always 90 degrees. This means that if one angle is known, the other angle can be easily found by subtracting the known angle from 90 degrees.
How do I use Trig Identities to find exact values?
Trig Identities are mathematical equations that relate the values of different trigonometric functions. These identities can be used to simplify expressions and find exact values of trigonometric ratios. By substituting known values into the identities, we can solve for the exact value of a trigonometric function.
What are the common Trig Identities used in finding exact values?
Some common Trig Identities used in finding exact values include the Pythagorean Identities, double angle identities, and half angle identities. These identities can be used to simplify expressions and solve for exact values of trigonometric functions.
Can the Complementary Angle Theorem be used to find exact values?
Yes, the Complementary Angle Theorem can be used to find exact values. By using the theorem, we can find the value of one angle and then use Trig Identities to solve for the value of the other angle. This allows us to find the exact values of trigonometric ratios for both angles.
How can I check my answers when finding exact values using Trig Identities?
One way to check your answers is to use a calculator to evaluate the original expression and the simplified expression. If the values are equal, then your answer is correct. You can also plug in the values of the angles into the original expression and the simplified expression to see if they produce the same result.
