Finding $f$ When $6\int_{1}^{x} f(t)\, dt+5=3x \, f(x)-x^3$
  • MHB
  • Thread starter sbhatnagar
In summary, the conversation discusses a differentiable function $f:[1,\infty)\to [2,\infty)$ with the initial condition $f(1)=2$. The given equation $6\int_{1}^{x}f(t)dt+5=3xf(x)-x^3$ for all $x\geq 1$ leads to the following questions:1) Find the value of $f(2)$.2) Find $\mathcal{L} \{ f(t)\}$.After a typo is corrected, the equation becomes $6\int_{1}^{x}f(t)dt+5=3xf(x)-x^3$. The resulting linear first term ODE
sbhatnagar
87
Let $f:[1,\infty)\to [2,\infty)$ be a differentiable function such that $f(1)=2$. If
$$ 6\int_{1}^{x} f(t)\, dt+5=3x \, f(x)-x^3$$
for all $x \geq 1$, then:
Mathematics news on Phys.org
$$ 6\int_{1}^{x} f(t)\, dt=3x \, f(x)-x^3$$
Something wrong here? If $x=1$, then the equation $\displaystyle 6\int_{1}^{x} f(t)\, dt=3x \, f(x)-x^3$ becomes $0=5.$
Sorry, I made a typo. The equation is
$$6\int_{1}^{x}f(t)dt+5=3xf(x)-x^3$$
I am really sorry about this.(Sadface)
sbhatnagar said:
... the equation is...
Deriving both terms You arrive to the linear first term ODE...
$\displaystyle \frac{d}{d x}\ f(x)= \frac{f(x)}{x} + x$ (1)
… with initial condition' $f(1)=0$ and the solving procedure is 'standard'...
Kind regards
$\chi$ $\sigma$
1) To find the value of $f(2)$, we can use the given equation to set up a system of equations. We know that $f(1)=2$, so we can substitute $x=1$ into the equation to get:
$6\int_{1}^{1} f(t)\, dt+5=3(1)\, f(1)-1^3$
This simplifies to $5=3f(1)-1$, which means $f(1)=2$. So now we know that $f(2)$ must satisfy the equation:
$6\int_{1}^{2} f(t)\, dt+5=3(2)\, f(2)-2^3$
To solve for $f(2)$, we can use integration by parts to simplify the integral on the left side:
$6\int_{1}^{2} f(t)\, dt = 6\left[f(t)\, t\right]_{1}^{2} - 6\int_{1}^{2} t\, f'(t)\, dt$
Since $f$ is differentiable, we can use the Fundamental Theorem of Calculus to get:
$6\int_{1}^{2} f(t)\, dt = 6\left[f(2)\, 2 - f(1)\, 1\right] - 6\int_{1}^{2} t\, f'(t)\, dt$
Substituting this into our original equation, we get:
$6\left[f(2)\, 2 - 2\right] - 6\int_{1}^{2} t\, f'(t)\, dt + 5 = 6f(2) - 13$
Simplifying further, we get:
$6f(2) - 1 = 6f(2) - 13$
This simplifies to $f(2)=12$. Therefore, $f(2)=12$.
2) To find $\mathcal{L} \{ f(t)\}$, we can use the Laplace transform property that states:
$\mathcal{L} \left\{ \int_{0}^{t} f(\tau)\, d\tau \right\} = \frac{1}{s} \mathcal{L} \{ f(t
FAQ: Finding $f$ When $6\int_{1}^{x} f(t)\, dt+5=3x \, f(x)-x^3$
What is the significance of finding the function f?
The function f is important because it represents the relationship between the independent variable x and the dependent variable f(x) in the given equation. It allows us to understand how changes in x affect the value of f(x) and vice versa.
How do you solve for f in the given equation?
To solve for f, we need to rearrange the equation to isolate f(x) on one side. This can be done by first distributing the 3x to the terms inside the integral and then bringing all the terms with f(x) to one side. Finally, we can factor out f(x) and divide both sides by the remaining expression to solve for f(x).
Can the equation be solved for f analytically?
Yes, the equation can be solved for f analytically by following the steps mentioned in the previous answer. However, the solution may not be simple and may require the use of numerical methods for approximation.
Are there any specific conditions or constraints for the function f?
Yes, the function f must be continuous and differentiable in the interval [1,x] in order for the integral to be defined. Additionally, the function must satisfy the given equation for all values of x in the interval.
Can the equation be solved for f using numerical methods?
Yes, the equation can be solved using numerical methods such as the Newton-Raphson method or the bisection method. These methods involve approximating the solution by repeatedly evaluating the given equation with different values of x until a solution is found within a given tolerance.
