MHB Finding for X given half-angle formulas
  • Thread starter Thread starter bsmithysmith
    Formulas
Given that csc(x) = 4, it follows that sin(x) = 1/4 for the interval 90º < x < 180º. Using the Pythagorean identity, cos(x) is determined to be -√(15)/4, as cosine is negative in the second quadrant. The half-angle formulas can then be applied to find sin(x/2), cos(x/2), and tan(x/2). Since sin(x/2) will be positive and cos(x/2) negative, the tangent value will also be negative. This process emphasizes understanding the relationships between the trigonometric functions rather than merely applying formulas.
bsmithysmith
If $$csc(x)=4$$, for $$90º<x<180º$$
$$sin\left(\frac{x}{2}\right)=$$
$$cos\left(\frac{x}{2}\right)=$$
$$tan\left(\frac{x}{2}\right)=$$
I'm definitely stumped on this one. I know that this is the half-angle formulas. Luckily we all have sheets we can use for the exam. I know that:
$$csc(x)=4$$ is the same as $$sin(x)=1/4$$, am I correct?
From there, I don't know if I should do a sine inverse, or plug and chug for the half-angle formulas.
$$sin\left(\frac{x}{2}\right)=±√(\left(\frac{1}{2}\right)(1-Cos(2x)))$$
And I don't know if I have to plug for x on both sides, or if I have to find what cosine(2x) is, or If I have to plug in the double angle formula at the end there.
Mathematics news on Phys.org
Yes, you are right:
$$\csc(x)=4\implies \sin(x)=\frac{1}{4}$$
Now, looking at the half-angle identities for sine, cosine, and tangent, we see we need to know $\cos(x)$ as well. So, we can use the Pythagorean identity:
$$\cos^2(x)=1-\sin^2(x)=1-\left(\frac{1}{4}\right)^2=\frac{15}{16}$$
Now, when we take the square root of both sides to get $\cos(x)$, which sign should we take on the right, given the quadrant in which $x$ is said to be?
MarkFL said:
Yes, you are right:
Since it's at quadrant 2, all cosine values will be negative, and sine values will be positive. I suspect it'll be the same thing for the sine value, but what about the tangent value? I have the cheat sheet available, but I'd still rather understand the process than plug and chug.
Yes, cosine is negative in the second quadrant, so since:
$$\cos^2(x)=\frac{15}{16}$$
we must therefore conclude that:
$$\cos(x)=-\frac{\sqrt{15}}{4}$$
So, now you have all you need to find the half-angled values of the primary trig. functions, using the various half-angle identities. If sine is positive, and cosine is negative, and given:
$$\tan(\theta)\equiv\frac{\sin(\theta)}{\cos(\theta)}$$
then what sign would you expect for the tangent function to have?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
