Finding galois group of Fq(x^(1/(q-1))) over Fq(x)
  • MHB
  • Thread starter oblixps
  • Tags
    Group
In summary, the conversation discusses finding G(F_{q}(x^{\frac{1}{q-1}})/F_{q}(x)), where q is the power of some prime. It is mentioned that F_{q}(x^{\frac{1}{q-1}}) is an extension of F_{q}(x) and the irreducible polynomial of x^{\frac{1}{q-1}} over F_{q}(x) is needed. The polynomial t^{q-1} - x is found to be irreducible over F_{q}[x] using Eisenstein's criterion. The roots of this polynomial are discussed, with one root being x^{\frac{1}{q-1}} and
oblixps
38
i am trying to find [tex] G(F_{q}(x^{\frac{1}{q - 1}}/F_{q}(x)) [/tex] where q is the power of some prime.
i know that [tex] F_{q}(x^{\frac{1}{q - 1}}) [/tex] is an extension of [tex] F_{q}(x) [/tex] so i need to find the irreducible polynomial of [tex] x^{\frac{1}{q - 1}} [/tex] over [tex] F_{q}(x)[/tex].
i found this to be [tex] t^{q - 1} - x [/tex] which is irreducible over [tex] F_{q}[x] [/tex] by Eisenstein's criterion. i know that every automorphism in the galois group must map roots of polynomials to roots of the same polynomial but i am having trouble finding the roots of [tex] t^{q - 1} - x [/tex]. besides [tex] x^{\frac{1}{q - 1}} [/tex], I am not sure what other roots it could have. can someone give me some hints on this?
suppose a is a non-zero element of Fq. since the non-zero elements of Fq form a finite cyclic group, we have:
aq-1 = 1, for all such a. thus the other q-2 roots are of the form ax1/(q-1) for a in Fq- {0,1}.
this shows that Fq(x1/(q-1)) is galois over Fq(x).
consequently, if b is a generator of Fq*, then any automorphism of Fq(x1/(q-1)) that fixes Fq(x) sends x1/(q-1) to bkx1/(q-1) for some k = 1,2...q-1.
on the other hand, [Fq(x1/(q-1)) :Fq(x)] = q-1, so these q-1 automorphisms must be all of Gal(Fq(x1/(q-1))/F​q(x)).
since the automorphism x1/(q-1) → bx1/(q-1)​ has order q-1, it appears we have a cyclic group of order q-1.
thank you! that was a very descriptive answer.
FAQ: Finding galois group of Fq(x^(1/(q-1))) over Fq(x)
1. What is the Galois group of Fq(x^(1/(q-1))) over Fq(x)?
The Galois group of Fq(x^(1/(q-1))) over Fq(x) is the group of automorphisms that fix the base field Fq and preserve the roots of the polynomial x^(q-1) - 1. In other words, it is the group of symmetries of the field extension Fq(x)^(1/(q-1)) over Fq(x).
2. How do you find the Galois group of Fq(x^(1/(q-1))) over Fq(x)?
To find the Galois group, you can use the theorem that states the Galois group of a finite separable extension is isomorphic to the group of automorphisms that fix the base field and the roots of the minimal polynomial of the extension. In this case, the minimal polynomial is x^(q-1) - 1.
3. What is the order of the Galois group of Fq(x^(1/(q-1))) over Fq(x)?
The order of the Galois group is equal to the degree of the extension, which is q-1. This means that the Galois group has q-1 automorphisms.
4. Are there any special cases for the Galois group of Fq(x^(1/(q-1))) over Fq(x)?
Yes, when q is a prime number, the Galois group is isomorphic to the cyclic group of order q-1. When q is a power of a prime, the Galois group is isomorphic to the direct product of the cyclic groups of order q-1.
5. What is the significance of the Galois group of Fq(x^(1/(q-1))) over Fq(x)?
The Galois group provides important information about the structure of the field extension Fq(x)^(1/(q-1)) over Fq(x). It also has applications in number theory, cryptography, and other areas of mathematics.
