Finding general solution of motion of forced harmonic oscillator
In summary, a forced harmonic oscillator is a system that undergoes periodic motion under the influence of an external force. To find the general solution of motion for this type of oscillator, one must use a differential equation and solve it using different methods. The motion of a forced harmonic oscillator can be affected by various factors, such as the frequency and amplitude of the external force, the mass and stiffness of the oscillator, and any damping present in the system. An example of a forced harmonic oscillator in real life is a child's swing. It differs from a simple harmonic oscillator as it is affected by an external force, making it more complex to analyze.
Redgal
1. The motion of a forced harmonic oscillator is determined by
d^2x/dt^2 + (w^2)x = 2cos t.
Determine the general solution in the two cases w = 2 and w is not equal to 2.
To be honest I've no idea where to start!
Can you solve the equation for a free harmonic oscillator?
d^2x/dt^2 + (w^2)x = 0
Can you guess the general shape of a solution for the forced oscillator? You can use this as ansatz for your equation, and solve it to get the coefficients.
FAQ: Finding general solution of motion of forced harmonic oscillator
What is a forced harmonic oscillator?
A forced harmonic oscillator is a system that undergoes periodic motion under the influence of an external force. This type of oscillator follows the laws of harmonic motion, where the restoring force is directly proportional to the displacement from equilibrium, but is also affected by an external force.
How do you find the general solution of motion for a forced harmonic oscillator?
To find the general solution of motion for a forced harmonic oscillator, you need to use the differential equation that describes the motion of the oscillator. This equation can be solved using various methods, such as the method of undetermined coefficients or the Laplace transform, to obtain the general solution.
What factors affect the motion of a forced harmonic oscillator?
The motion of a forced harmonic oscillator can be affected by several factors, including the frequency and amplitude of the external force, the mass and stiffness of the oscillator, and any damping present in the system. These factors can alter the amplitude, frequency, and phase of the motion of the oscillator.
Can you provide an example of a forced harmonic oscillator in real life?
One example of a forced harmonic oscillator is a child's swing. The child provides a periodic external force by pumping their legs, while the swing itself follows the laws of harmonic motion. The motion of the swing can also be affected by the child's weight, the length of the swing, and air resistance.
How is a forced harmonic oscillator different from a simple harmonic oscillator?
A forced harmonic oscillator is different from a simple harmonic oscillator because it is affected by an external force, while a simple harmonic oscillator only follows the laws of harmonic motion. This external force can change the amplitude, frequency, and phase of the motion of the oscillator, making it more complex to analyze than a simple harmonic oscillator.
