Finding General Solution vs Solving Differential Equations
In summary, to solve a single order differential equation without initial values, you need to separate if possible, integrate, and include the constant of integration. This will give you the general solution in terms of the dependent variable. However, if you are given initial values, you can substitute them into the general solution to obtain a particular solution. The general solution refers to the family of functions that satisfy the differential equation, while the particular solution is a single solution that satisfies both the differential equation and the initial/boundary conditions.
ifeg
If you are asked to solve a differential equation (single order) that has no initial values, then you separate if possible, integrate and include the Constant of integration, leaving the response in terms of the dependent variable, right?
So if you are given a single order differential equation, and asked to find the general solution, what do you do differently?
eg: $$ \frac {dy}{dx} - y = e^{3x} $$
Nothing.
CB
It depends on what you mean by general solution.
$\frac {dy}{dx} - y = e^{3x}$
In this case you have a linear differential equation.
If you wanted the general solution for a linear differential equation then you need to recognize the general form $\frac {dy}{dx} + P(x)y=Q(x)$ , and work with that.
If you are asking about a particular diff. eq then the general solution is nothing more than what you have described.
No, i don't think there's anything about a particular diff equation. i came across a question that asked just to find the general solution, but it had come after some other questions that asked to solve some diff equations, so i was wondering what, if any, was the difference between the two. I did some research and did see info about what you had suggested, with the P(x) y = Q(x) so i was wondering if that applied. Thanks for your assistance.
I think that general solution should reefer to the one you got without the initial values, and the a singular solution would be the one that you obtain after replacing the initial values.
The general solution is the FAMILY of functions that satisfies the Differential Equation (i.e. has the arbitrary constants).
The particular solution is the single solution of the Differential Equation that satisfies BOTH the DE AND the initial/boundary conditions.
Hi! When you are given conditions in the problem, for example y(0)=1 and y'(0)=0, you substitute this to the general solution which refers to the solution you have obtained from seperating and differentiating and you will obtain your partial solution :)
FAQ: Finding General Solution vs Solving Differential Equations
What is the difference between finding a general solution and solving a differential equation?
Finding a general solution involves finding a formula or set of formulas that can represent all possible solutions to a particular differential equation. Solving a differential equation, on the other hand, involves finding a specific solution that satisfies certain initial conditions.
Why is finding a general solution important?
Finding a general solution allows us to understand the behavior of a system over time and make predictions about its future behavior. It also helps us to determine the relationship between different variables in the system.
How do you find a general solution?
To find a general solution, you must first solve the differential equation by using various methods such as separation of variables, integrating factors, or using the characteristic equation. Once the solution is found, it can be expressed in terms of arbitrary constants which are then determined by applying the given initial conditions.
What is the benefit of solving a differential equation over finding a general solution?
Solving a differential equation allows us to determine the specific solution for a particular initial condition, which can be more useful for practical applications. It also allows us to solve more complicated systems that may not have a general solution.
Are there any limitations to finding a general solution or solving a differential equation?
Yes, there are limitations to both methods. Finding a general solution may not be possible for all types of differential equations, especially for non-linear or higher-order equations. Solving a differential equation may also be challenging for complex systems and may require numerical methods to approximate the solution.
