Finding gravitational acceleration near the surface of a planet with a satellite
In summary, to find the acceleration due to gravity near the surface of a planet with a satellite, you need to find the mass of the planet and substitute it into the formula for the law of universal gravitation. This will result in equations where r represents the distance from the center to center of the satellite and the planet, and R represents the radius of the planet. The value of r will depend on the altitude of the satellite, and in some cases, it may be approximated as equal to R.
katy123
find acceleration due to gravity near the surface of a planet with a satellite by finding the mass of the planet and substituting it into the formula for the law of universal gravitation
fc=mac
fg=GMm/R^2
fg=fc
fg=mg
my question is a general one, I have solved for the mass of the planet finding that 4pi^2r^3/t^2G= Mass of planet
Then, you substitute it into Fg=GMm/R^2
set this equal to mg
mg=GMm/R^2
my teacher has done this on two separate occasions once that results in
acceleration due to gravity=4pi^2r/t^2
and another where it is = 4pi^2r^3/(R^2)(T^2)
r= distance from center to center
R=radius of the big planet
how do you know which radius to use in these equations, and why did it cancel out in one and not in the other?
hi katy, try using the X2 and X2 buttons
It looks like in the first equation for the acceleration due to gravity your teacher approximated r ≈ R, which would be the case if you were on the surface of the Earth.
If you want to find the acceleration due to gravity on a satellite that is not near the surface of the earth, then r ≠ R.
r will just be the altitude of the satellite plus the radius of the Earth, which is R.
FAQ: Finding gravitational acceleration near the surface of a planet with a satellite
1. How is gravitational acceleration measured near the surface of a planet?
Gravitational acceleration can be measured using a satellite by monitoring its orbit around the planet. The satellite's motion is affected by the planet's gravitational pull, which can be used to calculate the planet's gravitational acceleration.
2. What factors affect the gravitational acceleration near the surface of a planet?
The gravitational acceleration near the surface of a planet is primarily affected by the planet's mass and radius. The larger the mass and smaller the radius of the planet, the stronger the gravitational acceleration will be.
3. How does the gravitational acceleration on different planets compare?
The gravitational acceleration on different planets varies depending on their mass and radius. For example, the gravitational acceleration on Earth is 9.8 m/s², while on Mars it is 3.7 m/s² and on Jupiter it is 24.8 m/s².
4. Can the gravitational acceleration near the surface of a planet change?
Yes, the gravitational acceleration near the surface of a planet can change due to various factors such as changes in the planet's mass or distance from other objects. However, these changes are typically very small and can only be detected with advanced instruments.
5. How is the gravitational acceleration on Earth affected by altitude?
The gravitational acceleration on Earth decreases slightly as altitude increases. This is because the distance between an object and the center of the Earth increases with altitude, resulting in a weaker gravitational pull. However, this effect is very small and only becomes significant at extreme altitudes, such as in orbit around the Earth.
