Finding height of buffer regions and viscous sublayer turbulent flow
In summary: From there, I can use the friction factor to calculate the wall shear stress and then use the definition of wall shear stress to calculate the height of the viscous sublayer and buffer regions.In summary, to calculate the wall shear stress and height of the viscous sublayer and buffer regions for a fluid flowing through a smooth pipe with given flow rate, density, and kinematic viscosity, one can use the Reynolds number to obtain the friction factor and then use the friction factor to calculate the wall shear stress. The definition of wall shear stress can then be used to calculate the heights of the viscous sublayer and buffer regions.
Master1022
611
117
A fluid flows through a smooth pipe of diameter [itex] 150 mm [/itex] with flow rate, density and kinematic viscosity of [itex] 180 m^{3} s^{-1} [/itex] and a density [itex] 700 kg [/itex] and [itex] 0.40 \times 10^{−6} 𝑚^2 [/itex] respectively. Calculate the wall shear stress and the height of the viscous sublayer and buffer regions.
Reynolds number
Hi,
I was recently attempting a problem about the height of buffer regions and viscous sublayer.
Question:
A fluid flows through a smooth pipe of diameter [itex] 150 mm [/itex] with flow rate, density and kinematic viscosity of [itex] 0.180 m^{3} s^{-1} [/itex] and a density [itex] 700 kg [/itex] and [itex] 0.40 \times 10^{−6} 𝑚^2 [/itex] respectively. Calculate the wall shear stress and the height of the viscous sublayer and buffer regions.
Method:
This was my method:
  1. Find the Reynolds number
  2. Use a correlation to get the friction factor [itex] f [/itex] from the Reynolds number
  3. Find the shear stress [itex] \tau [/itex] from the friction factor [itex] f [/itex]
  4. I am not sure how to get from the shear stress to the heights
1. Using the variables above
[tex] U = \frac{Q}{A} = \frac{4Q}{\pi D^2} = \frac{4 \times 180}{\pi \times (0.150)^2} = 10.185 m/s [/tex]
[tex] Re = \frac{D U}{\nu} = \frac{0.150 \times 10185.91636}{0.4 \times 10^{-6}} = 3.8197186... \times 10^{6} [/tex]
This seems like quite a high number to me (maybe even too large), but turbulent nonetheless
2. We are told that we have a smooth pipe and therefore I have used the Blasius correlation for a smooth pipe
[tex] f = 0.079 \times (Re)^{-0.25} = (3.8197186... \times 10^{9})^{-0.25} \times 0.079 [/tex]
3. Then we can get [itex] \tau [/itex] from this friction factor
[tex] \tau = \frac{1}{2} \times \rho \times U^2 \times f = 64.8812 Pa [/tex]
I also am not really sure how to make an attempt at the second part of the question at all. Any help or guidance would be greatly appreciated.
You have factors of 1000 that keep coming and going.
0.180 became 180, but you correctly got 10.185. Then that became 10185, yet you then got 3.8... 106 ok. Next, that became 3.8... 109.
Looks like you made two attempts and have posted a hybrid of the working.
The units on the kinematic viscosity should be m2/s.
Your calculation of the linear flow rate is a kind of average. You have effectively assumed it is the same across the flow. Don't you need to consider the velocity gradient? That is what will give rise to a "viscous sublayer", i.e. a non turbulent annulus.
Thank you for your response.
Yes, you are correct. I wrote the problem with converted units. In my original working, I had incorrectly converted the units and forgot to change it throughout the working.
That's right. I just blindly copied the question out without much thought about the units.
I see, that is a fair point. I don't believe I have really learned about different velocity profiles in pipes, but some searching on the internet yielded a general expression of the form:
[tex] u = \frac{1}{k} \sqrt{\frac{\tau_w}{\rho}} ln(y) + c [/tex]
Does that seem like a reasonable place to start? If it is the right method, I can go to read up more on applying the boundary conditions correctly, etc. The only other velocity profile, which I have learned about, for turbulent flow is the 1/7-th power law. However, I was under the impression that is only applicable to flat-plate flows.
I'm out of my depth here, but I see the exponent in the power law for the velocity distribution depends on the Reynolds number, so it gets tricky: across the width of the pipe the velocity changes, so the Reynolds number changes, so the way the velocity changes changes. Ouch.
1/7 seems to be some commonly observed average.
I think we can assume the flow is fully developed, in which case the velocity distribution will be a constant. Then, I can use a Fanning diagram, instead of the Blasius relation, to obtain the friction factor ## f ##.
Related to Finding height of buffer regions and viscous sublayer turbulent flow
1. What is the purpose of finding the height of buffer regions and viscous sublayer turbulent flow?
The purpose of finding the height of buffer regions and viscous sublayer turbulent flow is to better understand the behavior and characteristics of turbulent flow. This information can be used to improve fluid dynamics in various industries, such as aerodynamics, hydraulics, and chemical engineering.
2. How is the height of buffer regions and viscous sublayer turbulent flow determined?
The height of buffer regions and viscous sublayer turbulent flow is typically determined through experimental measurements and mathematical models. This involves analyzing the velocity profiles and turbulence characteristics of the flow at various distances from the boundary.
3. What factors affect the height of buffer regions and viscous sublayer turbulent flow?
The height of buffer regions and viscous sublayer turbulent flow can be influenced by several factors, including the type of fluid, the flow velocity, the surface roughness of the boundary, and the Reynolds number (a dimensionless parameter that describes the ratio of inertial forces to viscous forces).
4. Why is it important to accurately determine the height of buffer regions and viscous sublayer turbulent flow?
Accurately determining the height of buffer regions and viscous sublayer turbulent flow is crucial for predicting and controlling the behavior of turbulent flow. This information can help engineers design more efficient and stable systems, reduce energy consumption, and minimize the risk of turbulence-related issues, such as drag and flow separation.
5. What are some potential applications of understanding the height of buffer regions and viscous sublayer turbulent flow?
Understanding the height of buffer regions and viscous sublayer turbulent flow has many practical applications. It can be used to improve the design of aircraft wings and propellers, optimize the performance of pumps and turbines, and enhance the mixing and heat transfer in industrial processes. Additionally, this knowledge can also be applied in environmental studies, such as predicting the dispersion of pollutants in the atmosphere and water bodies.
  • Classical Physics
  • Materials and Chemical Engineering
