Finding height using the direction cosines
In summary: PO is the height of the mountain. In summary, to find the height of the mountain using direction cosines, one can use trigonometry and the given direction cosines to find the angles and sides of the triangle formed by the observer, the base of the mountain, and the top of the mountain. By using the sine rule and the known distance between the observer and the base of the mountain, the height of the mountain can be calculated.
janahan
Sorry for the re-post
http://books.google.ca/books?id=nYR...g direction cosines to measure height&f=false
The obove link has a coopy of the question as it is hard to describe.
If you find the link is too hard to read here is the data
Direction cosines:
of Rap(from point a to top of mountain):
cos theta x= .5179
cos theta y= .6906
cos theta z= .5048
of Rbp(from point b to top of mountain):
cos theta x=-.3743
cos theta y=.7486
cos theta z=.5472
b and a are 10000m apart. Find how high point p is.
It is on page 57 #2.82 (The mount everest question)
I attemted the question in a number of ways but can't seem to come to an answer. I tried Looking at it as two right angled triangles and using trig. I am not really sure what i can do with the direction cosines either.
Draw a perpendicular PO on the base of the mountain. Let PD, PE and PF on x, y and z axis passing through A.
AD = AP*cos(α)
AE = AP*cos(β)
[cos(α) = 0.5179, cos(β) = 0.6906]
Now tan(OAD) = AE/AD. Find angle OAD. Similarly find angle OBD. from these two angles find the third angle AOB. Using sine rule in the triangle AOB, find Ao and BO.
cos(γ) = 0.5048 is given. From that find tan(γ) which is equal to PO/AO. AO is known. Find PO.
I would approach this problem by first understanding the concept of direction cosines and how they relate to height measurement. Direction cosines are unit vectors that represent the direction of a line or vector in three-dimensional space. In this case, the direction cosines are being used to represent the direction from two points (a and b) to a third point (p) on a mountain.
To solve this problem, we can use the fact that the direction cosines are related to the angle between the line and each of the coordinate axes. We can also use the distance between points a and b (10,000m) to help us find the height of point p.
First, we can draw a diagram to visualize the problem. From point a, we can draw a line to the top of the mountain (point p) and label it as vector Rap. Similarly, from point b, we can draw a line to the top of the mountain and label it as vector Rbp.
Next, we can use the direction cosines to find the angles between these vectors and the coordinate axes. This will give us the angles between the lines Rap and Rbp and the horizontal plane. We can then use trigonometry to find the height of point p.
Using the given data, we can calculate the angles between the vectors and the horizontal plane:
θx = cos^-1(0.5179) ≈ 59.5°
θy = cos^-1(0.6906) ≈ 45.2°
θz = cos^-1(0.5048) ≈ 61.2°
Next, we can use the law of sines to find the angle between the lines Rap and Rbp:
sin(θx)/10,000 = sin(θy)/h
Where h is the height of point p. Solving for h, we get:
h = 10,000(sin(θy)/sin(θx)) ≈ 11,900m
Therefore, the height of point p is approximately 11,900m. We can also use the direction cosines of Rbp to double check our answer:
sin(θx)/10,000 = sin(θz)/h
Solving for h, we get the same answer of approximately 11,900m.
In conclusion, using direction cosines is a useful method for measuring height in three-dimensional space. By understanding the
Related to Finding height using the direction cosines
What is the concept of "Finding height using the direction cosines"?
"Finding height using the direction cosines" is a method used in mathematical and scientific fields to determine the vertical distance of a point from a given reference plane. This can be useful in various applications such as navigation, surveying, and physics.
What are direction cosines and how are they used in finding height?
Direction cosines are the cosines of the angles between a vector and each of the coordinate axes. In "Finding height using the direction cosines", the direction cosines are used to find the angle between the vector representing the point and the reference plane. This angle can then be used to calculate the height of the point from the reference plane.
What are the steps involved in finding height using the direction cosines?
The steps involved in finding height using the direction cosines are as follows:
1. Determine the coordinates of the point in question.
2. Determine the coordinates of the reference plane.
3. Calculate the direction cosines of the vector between the point and the reference plane.
4. Use the direction cosines to find the angle between the vector and the reference plane.
5. Use trigonometric functions to calculate the height of the point from the reference plane.
What are some practical applications of "Finding height using the direction cosines"?
"Finding height using the direction cosines" has various practical applications, including:
1. Navigation: In navigation, direction cosines can be used to determine the altitude of an object or location in relation to the horizon.
2. Surveying: Direction cosines can be used in surveying to calculate the height of a point from a reference plane, such as the ground.
3. Physics: In physics, direction cosines can be used to determine the angle of elevation or depression of an object, which can then be used to calculate its height.
Are there any limitations or assumptions when using "Finding height using the direction cosines"?
Like any mathematical or scientific method, there may be limitations and assumptions when using "Finding height using the direction cosines". Some possible limitations include:
1. The reference plane must be flat and known.
2. The point must be above or below the reference plane.
3. The direction cosines may not be accurate if there are errors in the measurements of the point or reference plane coordinates.
4. The method assumes that the Earth is a perfect sphere, which may not be the case in all situations.
