Finding higher order Derivatives
In summary: Then you will keep taking the derivative of zero which is zero over and over again till the end of the derivative instead of the previous case where you only got zero once, instead it will occur multiple times for that specific... k>n.
tmlrlz
29
Let p be an arbitrary polynomial
p(x) = anxn + an-1xn-1 + ... + a1x + a0, an cannot equal 0.
a) Find (dn/dxn)[p(x)]
b)What is (dk/dxk)[p(x)] for k>n
Im actually not really sure what to do for this question.
For the first part i tried to take the first three derivatives and got
(d/dx)[p(x)] = a1
(d2/dx2)[p(x)] = 2a2x + a1
(d3/dx3)[p(x)] = 3a3x2 + 2a2x + a1
(dn/dxn)[p(x)] = nanxn-1 + (n-1)a(n-1)xn-2 + ... + a1
Thats my guess, I am not sure of how to do it.
As for part b:
I don't even know how to approach this question, my only assumption is that its the same answer again with all the n's replaced with k's. I am certain this is wrong so please help me do this question both a and b. Thank you.
Welcome to PF, tmlrlz! :smile:
What you have calculated is d/dx in each case.
dn/dxn means that you take the derivative n times.
I thought i did that for part a, did i do it wrong? And how would you go about doing part b, what is it asking and how is it different from part a? Thank you.
Let me give you an example:
But what you actually did was:
(d/dx)[p(x)] = 2a2x + a1
It should be:
Can you do this for say n=3?
If you understand what is intended for part a, I think you'll see what is intended for part b.
The difference is that the n in the first part is the degree of the polynomial. The k in the second part is just any integer greater than the degree of the polynomial.
Yes, this is true.
So I guess you answered the last part of your own question.
It should be:
oh i can't believe that i forgot to do the rest of the derivative!
so for n = 3
(d3/dx3)[p(x)] = 6a3
And then you can find part a
(dn/dxn)[p(x)] = n! * (an)
However i am still confused as to what part b is requiring?
so for n = 3
Right! :smile:
Okay, let's pick a k>n.
I'll pick k=n+1.
What is (dn+1/dxn+1)[p(x)]?
I like Serena said:
Right! :smile:
I'll pick k=n+1.
So then that means that when n = 1 we are taking the derivative of d2/dx2 right?
I took the first 3 derivatives again
when n =1
d2/dx2[p(x)] = d/dx (a1) = 0
when n =2
d3/dx3[p(x)] = 0
when n =3
d4/dx4[p(x)] = 0
so that means that
(dk/dxk)[p(x)] = 0
right? i hope!
when n =1
when n =2
d3/dx3[p(x)] = 0
when n =3
d4/dx4[p(x)] = 0
so that means that
(dk/dxk)[p(x)] = 0
right? i hope!
Yep! :wink:
What do you think will happen if we pick k=n+2?
Or k=n+3?
Or any k>n?
I like Serena said:
Yep! :wink:
Or k=n+3?
Or any k>n?
Then you will keep taking the derivative of zero which is zero over and over again till the end of the derivative instead of the previous case where you only got zero once, instead it will occur multiple times for that specific derivative
So? Any other questions?
Thank you so much for your help. I do have more questions but i do not wish to trouble you, if you would like you can look at the question i posted, i seem to be having trouble on it even though people have been trying to help me, https://www.physicsforums.com/showthread.php?p=3593450&posted=1#post3593450
Thank you once again!
FAQ: Finding higher order Derivatives
1. What are higher order derivatives?
Higher order derivatives refer to the derivatives of derivatives. In other words, they are the rates of change of rates of change. The first derivative is the rate of change of a function, the second derivative is the rate of change of the first derivative, and so on.
2. Why do we need to find higher order derivatives?
Higher order derivatives are useful for understanding more complex patterns of change in a function. They can help us analyze the curvature, concavity, and inflection points of a function, which are important in many applications such as optimization and modeling in science and engineering.
3. How do you find higher order derivatives?
To find higher order derivatives, we use the same rules and techniques as finding the first derivative. We can use the power rule, product rule, quotient rule, and chain rule, depending on the function. However, each time we take a derivative, we decrease the degree of the original function, so the process can become more complicated with each successive derivative.
4. Can all functions have higher order derivatives?
No, some functions do not have higher order derivatives. For example, a function with a corner or discontinuity does not have a derivative at that point, and therefore cannot have higher order derivatives. Additionally, some functions may have infinitely many derivatives, while others may only have a few.
5. What is the difference between the nth derivative and the nth order derivative?
The nth derivative refers to the result of taking the derivative n times, while the nth order derivative refers to the derivative of order n. In other words, the nth derivative is the result, while the nth order derivative is the process or operation of taking the derivative n times.
