Finding Induced EMF of secondary coil
In summary, the problem involves a primary and secondary coil with 15 turns and 16000 loops respectively. The primary coil is supplied with 25000 V, and the question is asking for the induced emf in the secondary coil. This problem involves a commonly used device and can be solved by referencing course materials.
Toto
There's a primary and secondary coil. The primary coil has 15 turns, and the secondary coil has 16000 loops. The 25000 V is applied to the primary coil, what will be the induced emf in the secondary coil.
Very confused as to how to approach this problem with the two coils in place.
You should recognize the setup from your course notes or text. It forms a very common device. Look it up and make an attempt.
Related to Finding Induced EMF of secondary coil
1. What is induced EMF?
Induced EMF (electromotive force) is the voltage generated in a conductor when it is subjected to a changing magnetic field. It is a result of Faraday's law of electromagnetic induction.
2. How is induced EMF measured?
Induced EMF can be measured using a voltmeter or multimeter connected to the ends of the conductor. The reading will give the magnitude of the induced voltage.
3. What factors affect the magnitude of induced EMF?
The magnitude of induced EMF is affected by the rate of change of the magnetic field, the number of turns in the conductor, and the strength of the magnetic field.
4. How is the induced EMF of a secondary coil calculated?
The induced EMF in a secondary coil can be calculated using the equation E = -N(dΦ/dt), where E is the induced EMF, N is the number of turns in the coil, and dΦ/dt is the rate of change of the magnetic field.
5. What is the purpose of finding the induced EMF of a secondary coil?
Finding the induced EMF of a secondary coil is important in understanding the principles of electromagnetic induction and its applications, such as in generators and transformers. It also helps in studying the relationship between magnetic fields and electric currents.
