Finding initial velocity of an object reaching 10 m high
In summary, there are two ways to calculate initial velocities for an object just clearing over a 9.99 m wall. One way is to use kinematics equations and the other way is to use conservation of energy. However, using a 45 degree angle as suggested by the teacher would not satisfy the problem conditions. The optimal solution would be to use a launch angle of 45 degrees, but it is not clearly stated in the problem. To solve for the launch velocity, the SUVAT equation can be used. Another approach is to construct a parabola with a 45 degree launch angle and solve for the unknown variables.
Blobikins
25
I need to find two ways to calculate initial velocities (2 versions) of an object just clearing over a 9.99 m wall.
Way 1 I was trying is to say dx = 40m , dy = 10m, ay= -9.81m/s^2.
The thing is, I can't get started even for y because I'm missing too many variables, namely viy, vfy, and t.
The second way is to say the angle is 45 degrees, so viy is (something)sin45 and vx is (something)cos45.
But again, I'm missing too many variables to calculate it.
Am I missing something?
I don't see any reason to assume a 45 degree angle or any angle other than straight up. One way to get an equation is to use "F= ma" or "a= F/m". For gravity, F= -mg so that just becomes a= -g. Then v= -gt+ v0 and x= -(g/2)t^2+ v0t= t(v0- gt). That's a parabola. Where is the vertex?
The other way is to use "conservation of energy". At 10m the total energy, potential energy plus kinetic energy, is, since the velocity is 0, is just the potential energy= mgh= 10mg. When it just starts, the potential energy is 0 so the kinetic energy is (1/2)mv^2= 10mg. What is v?
Ah, I'm sorry, I forgot to say a 8.99. M wall 40 m away, so the dx would be 80, sorry.What am I missing?
If you assume 45 degree launch angle you do have enough knowns values to solve for the launch velocity. Look up the SUVAT equations..
If you assume the angle is 45 degree you have too many restrictions. The object won't be "just clearing the wall".
What you should assume is that the trajectory has its highest point at 10 m above the ground.
Alright, so I've finished the equation 1 way, with the peak being 10 m, but my teacher wants it done two ways. He suggested choosing 45 degrees as an angle, but how exactly would I go about doing that?
But 45 degrees does not satisfy the setup of the problem. How can you solve with contradictory conditions?
It's either "just clearing the wall" or 45 degrees angle. Given that you keep the two distances (10 m and 40 m) unchanged.
You need to have the problem very clearly formulated before thinking about solution.
By my thinking 45 Deg (frictionless) exactly satisfies the set up - as the optimal, lowest launch Velocity - granted the problem does not state optimal !
So, I was thinking so at 40m it's just reaching 10m, not the peak at that point.
With the angle of 45 degrees, how do I do that?
I am reading again and is the problem really "find two WAYS" -- Vs two solutions? ( there are infinite solutions)
Apologies, I meant 2 solutions.
Would it be possible for me to do a theoretical parabola where the midpoint is 80,20, so then a quarter of the time would be 40,10?
It is a single math problem - and pick two solutions. The advantage of the 45 is since it is optimal it is the minimum V init.
I don't know what you're getting at.
Pick two solutions?
I feel I'm missing a variable if I just have 45?
What exactly do I do?
So basically I'td be x - ?cos45 = vx
d = 40
y =
?sin45 = viy
d =10
a = -9.8
t = ?
How do I put this together to make a proper equation
The SUVAT equation I was hoping you would find is...
s = ut + 0.5at2
u = Vsin(45)
|a| = 9.8m/s/s
s = 9.99m
Brute-force method: Construct a parabola starting at (0,0) with a 45o launch angle, peaking at, say, (B,A) and landing at (2B,0).
The general form is: y = A-C(x-B)^2.
You know another point on the curve: (40,10).
You know dy/dx at (0,0) = 1.
Solve for A, B, and C.
Related to Finding initial velocity of an object reaching 10 m high
1. How do you calculate the initial velocity of an object reaching a height of 10 meters?
The initial velocity can be calculated using the equation vi = √(2gh), where vi is the initial velocity, g is the acceleration due to gravity (9.8 m/s2), and h is the height reached by the object (10 m).
2. Is the initial velocity affected by air resistance?
Yes, the initial velocity is affected by air resistance. Air resistance is a force that opposes the motion of an object and can decrease the initial velocity of an object.
3. Can the initial velocity be negative?
Yes, the initial velocity can be negative if the object is projected downwards. This indicates that the object is moving in the opposite direction of the positive direction, which is usually upwards.
4. Does the mass of the object affect the initial velocity?
Yes, the mass of the object can affect the initial velocity. Heavier objects require more force to be projected to the same height as lighter objects, therefore their initial velocity may be different.
5. Can the initial velocity be calculated if the object is not in free fall?
Yes, the initial velocity can still be calculated if the object is not in free fall. In this case, the initial velocity can be calculated using the conservation of energy principle, where the initial kinetic energy of the object is equal to its potential energy at the top of its trajectory.
