Finding input impedance with smith chart
In summary, to find the input impedance on the smith chart, you need to enter at the normalized load impedance and rotate clockwise until your starting length is increased by 3λ/8. This process can be better understood through graphical demonstrations.
DODGEVIPER13
672
Find an input impedance of a 50 Ω transmission line of length transmission line of length 3λ/8
terminated with a load of 10 Ω.
Zl'=(Zl/Zc)
Zin(L)=(Zl-jtan(kL))/(1+jZltan(kL))
I have uploaded my attempt how far off am I?
  • smithchart.pdf
Ok so 0 on the smith chart is the line which goes down the middle and R=0 is at the final outer 0 but where is the imaginary part 0.02?
Look at the values on the outer ring. The imaginary lines will extend from there. Why are you looking for the input impedance on the smith chart after computing it? Normally if you are asked to find the input impedance using the smith chart you do not actually compute the input impedance numerically, you actually do the entire analysis on the smith chart.
Ok so how should I proceed? I am confused do you have any more hints
To find the input impedance using the smith chart you want to enter the smith chart at the normalized load impedance. You then rotate about the point where the reflection coefficient is zero clockwise until your starting length is increased by 3λ/8. The starting length will be the outer point that is associated with a straight line segment extending from the centre of the smith chart (zero reflection) and passing through your normalized load impedance.
It is rather tedious to try and explain this process via words. Graphical demonstrations are much easier to get the point across.
FAQ: Finding input impedance with smith chart
1. What is a Smith Chart and how is it used to find input impedance?
A Smith Chart is a graphical tool used in radio frequency (RF) engineering to analyze and design transmission lines and impedance matching networks. It is typically used to find the input impedance of a circuit, which is the ratio of voltage to current at the input terminals. To find the input impedance, the Smith Chart is used to plot the reflection coefficient of the circuit, which is then converted to the input impedance using the proper scaling.
2. What is the reflection coefficient and how does it relate to input impedance?
The reflection coefficient is a measure of the amount of signal that is reflected back when it reaches a discontinuity in a transmission line. It is represented by the Greek letter ρ (rho) and is defined as the ratio of the reflected voltage to the incident voltage. The reflection coefficient is directly related to the input impedance of a circuit, as the input impedance is equal to the characteristic impedance of the transmission line multiplied by the reflection coefficient.
3. How do you plot a circuit on a Smith Chart to find input impedance?
To plot a circuit on a Smith Chart, you first need to determine the characteristic impedance of the transmission line and the reflection coefficient of the circuit. The characteristic impedance can be determined from the properties of the transmission line, while the reflection coefficient can be calculated using the load impedance and the characteristic impedance. Once you have these values, you can use the Smith Chart to plot the reflection coefficient and then convert it to the input impedance using the proper scaling.
4. What are the benefits of using a Smith Chart to find input impedance?
The Smith Chart offers several benefits for finding input impedance. Firstly, it provides a visual representation of the reflection coefficient, which can help in understanding the behavior of the circuit. Additionally, the Smith Chart allows for easy conversion between reflection coefficient and input impedance, making the calculation process more efficient. It also enables quick evaluation of different impedance matching configurations, making it a valuable tool for RF engineers.
5. Are there any limitations to using a Smith Chart to find input impedance?
While the Smith Chart is a useful tool for finding input impedance, it does have some limitations. It is most accurate for circuits with low to moderate reflection coefficients, and may not provide accurate results for circuits with high reflection coefficients. Additionally, the Smith Chart assumes a single frequency and cannot be used for circuits with varying frequency. It is also limited in its ability to analyze complex circuits with multiple impedance values. In these cases, more advanced techniques may be needed to accurately find the input impedance.
