Finding integral of dot product of F and dl
In summary, the conversation is about finding the integral of a vector field using different methods along a straight line path from (0,0,0) to (1,2,3) in Cartesian coordinates. The first method uses dl as (^x + 2^y + 3^z)dx and evaluates to yz+z+3/2y. The second method involves adding the individual solutions from three different paths and yields yz+2zx+3xy. However, both solutions are incorrect as the final answer should be a numerical value. The correct method involves parametrizing the path and expressing x,y,z in terms of each other, then performing the line integral. For part c), the question hints at a vector
r3dxp
1. For the vector field
F = yz ˆx + zx ˆy + xy ˆz
(^x means the unit vector of x)
find the integral of F • dl from (0, 0, 0) to (1, 2, 3) in Cartesian coordinates
in each of the following ways:
(a) along a straight line path from (0, 0, 0,) to (1, 2, 3)
(b) along straight line paths from (0, 0, 0,) to (1, 0, 0), then from (1, 0, 0)
to (1, 2, 0), then from (1, 2, 0) to (1, 2, 3)
(c) without choosing a particular path
for part a), i used the dl as (^x + 2 ^y + 3 ^z)dx since vector r= ^x + 2 ^y + 3 ^z
thus, integral of F dot dl = yzx + z(x^2) + 3/2 (x^2)y evaluated from x=0 to x=1, and get yz+z+3/2y
for part b), i added the three different solutions from path 1, path 2, and path 3.
path1: using dl1=dx ^x, integral of path 1 of F*dl1 = yz
path2: using dl2=dy ^y, integral of path 2 of F*dl2 = 2zx
path3: using dl3=dz ^z, integral of path 3 of F*dl3 = 3xy
so my solution to part b) is yz+2zx+3xy
i was wondering, are my solutions to part a) and part b) correct? If not, please guide me through on how to get the solutions to part a,b, and c. thanks alot!
r3dxp said:
for part a), i used the dl as (^x + 2 ^y + 3 ^z)dx since vector r= ^x + 2 ^y + 3 ^z thus, integral of F dot dl = yzx + z(x^2) + 3/2 (x^2)y evaluated from x=0 to x=1, and get yz+z+3/2y
No, dl is always [tex] \left(\begin{array}{c}dx\\dy\\dz \end{array} \right )[/tex]. Your final answer is supposed to be a numerical value anyway. A routine method would be to parametrise the path taken to evaluate the line integral along the straight line path. However, in this case since the path taken is relatively simple, we can perform the line integral without the parametric method. So firstly find a way to express x,y,z in terms of each other along that straight line path. The vector path representation of that straight line is [tex]\mathbf{r}(t) = t \left(\begin{array}{c}1\\2\\3 \end{array} \right )[/tex] as can be seen just by visualising the path.
So from the above you can deduce that along the straight line path, x=t, y=2t,z=3t and from this, x=1/2y=1/3z. Now that you've expressed x,y,z in terms of each other you can perform the line integral.
So we have [tex]\int_{(0,0,0)}^{(1,2,3)} \left(\begin{array}{c}yz\\zx\\xy \end{array} \right ) \cdot \left(\begin{array}{c}dx\\dy\\dz \end{array} \right ) [/tex]. So now, you just need to evaluate each of the dot products, perform the integral for each dx,dy,dz, taking care to express the Fx,Fy,Fz components in terms of x when integrating with respect to dx, in terms of y when integrating wrt to dy and so on.
As above, your answer here is incorrect because you're supposed to get a numerical answer. For b) it's just performing multiple line integrals by the method explained above. For c) the way the question is phrased serves as a strong hint as to how one can perform a line integral without specifying any path at all. What kind of vector field do you think F is such that the path taken for line integrals doesn't matter? How can you verify that?
Your solutions for part a) and part b) are correct. For part c), you can use the fundamental theorem of calculus to evaluate the integral without choosing a particular path. The fundamental theorem of calculus states that if F is a continuous vector field and C is a smooth curve from point A to point B, then the line integral of F along C is equal to the difference of the scalar field F evaluated at points A and B:
∫F•dl = F(B) - F(A)
In this case, point A is (0,0,0) and point B is (1,2,3). So, we can simply evaluate the scalar field F at these two points and take the difference to get the line integral.
F(A) = 0yz + 0zx + 0xy = 0
F(B) = 2yz + 3zx + 6xy = 2yz + 3zx + 6xy
Therefore, the line integral of F along any path from (0,0,0) to (1,2,3) is equal to 2yz + 3zx + 6xy. This is the solution for part c).
I hope this helps clarify the solutions for all three parts. Let me know if you have any further questions.
FAQ: Finding integral of dot product of F and dl
What is the dot product of F and dl?
The dot product of F and dl is a mathematical operation that takes two vectors as input and returns a scalar value. It is calculated by multiplying the magnitude of the first vector with the cosine of the angle between the two vectors.
Why is it important to find the integral of dot product of F and dl?
Finding the integral of the dot product of F and dl is important in physics and engineering, as it helps in calculating the work done by a force on an object. It also helps in calculating the total displacement of an object under the influence of a force field.
How is the integral of dot product of F and dl related to line integrals?
The integral of dot product of F and dl is a type of line integral, specifically a path integral. It is used to calculate the work done by a force along a specific path in a vector field. It is also known as a line integral with respect to arc length.
What is the process for finding the integral of dot product of F and dl?
The process for finding the integral of dot product of F and dl involves first setting up the line integral with respect to arc length for the given vector field. Then, the dot product of F and dl is calculated and integrated along the path of the line integral. Finally, the limits of integration are determined based on the start and end points of the path.
Can the integral of dot product of F and dl be negative?
Yes, the integral of dot product of F and dl can be negative. This indicates that the work done by the force is in the opposite direction of the displacement of the object. Positive values indicate that the force and displacement are in the same direction, while negative values indicate they are in opposite directions.
