MHB Finding $|k|$ of the Polynomial $x^3-kx+25$
  • Thread starter Thread starter anemone
    Polynomial
The polynomial \(x^3 - kx + 25\) has three real roots, with two roots summing to 5, leading to the conclusion that \(a = -5\). Using Vieta's formulas, it is determined that \(k = 20\) after substituting into the polynomial equation. An assumption that the other two roots are complex leads to a contradiction, reinforcing that all roots must be real. The calculations confirm that \(k = 20\) is the only valid solution. The discussion clarifies that there was a typographical error regarding the sign of \(k\), which has been corrected.
anemone
MHB
POTW Director
The polynomial $x^3-kx+25$ has three real roots. Two of these root sum to 5. What is $|k|$?
Mathematics news on Phys.org
[sp]
Let the roots be a, b, and c.
Then by Vieta's formula
a + b + c = 0
Take b + c = 5. Then a = -5,
So we know that
[math]a^3 - k a + 25 = 0[/math]
[math](-5)^3 - k ( -5 ) + 25 = 0[/math]
k = 20
Note that we haven't used the condition that all roots are real, so let's assume that b and c are complex and that this gives a contradiction.
We know that a = -5 and that b and c are, by assumption, complex. So let b = m + in and c = 5 - (m + in).
The other Vieta formula says that
abc = 25
$$(-5) ( m + in) ( 5 - (m + in) ) = 25$$
[math](-m^2 + 5m + n^2) + (5n - 2mn)i = -5[/math]
Using the second term
$$5n - 2mn = 0$$
So n = 0 or m = 5/2.
Let m = 5/2 and put it into the first term:
[math]-m^2 + 5m + n^2 = -5[/math]
[math]- \left ( \dfrac{5}{2} \right ) ^2 + 5 \left ( \dfrac{5}{2} \right ) + n^2 = -5[/math]
[math]n^2 = -\dfrac{45}{4}[/math]
which says that [math]n^2 < 0[/math], which is impossible.
Thus n = 0 and the solution for k = 20 stands as the only possible k.
[/sp]
-Dan
Above is good method and here is my
as $x^2$ term is zero and sum of 2 roots is 5 so $3^{rd}$ root is -5 so we have the product of 2 roots = 5 (as product of all roots -25)
$x^3-xk+25 = (x+5)(x^2- 5x + 5) = x^3 -5x^2+5x + 5x^2 - 25 x + 25 = x^3 -20x + 25$
comparing with given equation we have k = 20 and hence $| k | = 20$
we have to check that $x^2-5x+5=0$ is having real roots or not. We have discriminant = $5^2-20= 5 >0 $ so real roots
so ans 20
[sp]
There's a typo.
[math]x^3 - k x + 25 = x^3 - 20 x + 25 \implies k = 20[/math], not -20.
[/sp]
-Dan
topsquark said:
[sp]
There's a typo.
[/sp]
-Dan
Thanks I have done the needful in line for the flow
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 48 ·
