Orims
- 2
1. This problem has been slowly eating me for the past 2 hours. I've done everything I can but I can't seem to answer it. The pH at the equivalence point in the titration of 100 mL of a 0.1M monoprotic acid solution with a 0.1M strong base solution is 8.12 at 25 degrees C. What is the Ka of the acid?
I know the Ka of the acid can be found using pH= pKa + log ([A-]/[HA]) but only if it is before the equivalence point.
3. I found out that the equivalence point was when 100 mL of strong base have been added (same molarity as weak acid, so equivalence point = double the volume of initial acid solution). This would make the half equivalence point 150 mL.
