Finding Kinetic Energy on a Vertical Circle with Friction
In summary: Summary: In summary, a 200g object slides down a frictionless ramp from a height of 60 cm and then follows an arc of a circle with a radius of 20 cm and a coefficient of kinetic friction of 0.4. The angle at the end of the ramp is 120 degrees and points P1 and P2 are at the same height. The first question asks for the speed of the object at P1, which can be found using the Work-Energy Theorem. The second question asks for the kinetic energy of the object at P2, which is more complicated and may require a numerical or differential equation solution. The formula for total energy dissipated as friction is given, but a method for solving it is not
  • #36
Just as I suspected: you are sharper than the author of this particular physics problem (and sharper than me). Kf = 0.71 J is the result that I get if I ignore the centripetal acceleration (as I would have done if you did not mention it)! In other words, the official answer is incorrect, and you have identified a critical flaw in this problem.
This is actually quite interesting: it demonstrates the profound importance that the centripetal acceleration plays in a problem where the author probably just assumed (without verification) that it could be neglected. As it turns out, not only is the correct answer (which includes the effect of centripetal acceleration) quite different, it is in fact utter nonsense. (Or, you could classify this as a trick question, because it asks for a quantity that is not allowed to exist according to the problem.) This shows the danger of making "simplifying assumptions", which is the phrase that was most likely in the subconscious of the problem's author. Let this be a good lesson for all of us.
  • #37
It's actually quite fascinating, how the inclusion of centripetal acceleration changes the answer by so much.
I suppose it could be a trick question, but only if the answer said as much...otherwise, I'll chalk that up to an error in the problem (or, rather, an error in the attempt made at a solution by the problem's author).
Of course, the part I found most beneficial was learning how to set up the problem as an ODE, and learning how to use integrating factors...
Thank you very much for your help!
  • #38
jhae2.718 said:
I suppose it could be a trick question, but only if the answer said as much ...
That would be quite a nasty trick, especially since the official answer is wrong.
I would hate to beat this problem to death, especially since it has no solution (as stated). But, for the sake of learning and practicing diff. eq., you may benefit from actually approaching this problem without setting up the integral equation. That is, try to solve the problem directly in terms of force rather than energy. With some trickery, you can derive the same diff. eq., and it will demonstrate another common "trick" in solving diff. eq.s: nontrivial usage of the chain rule, both implicit and explicit.
So, in case you find some spare time and decide to do this, here is your first hint:
You still want the independent variable to be position, but the force equation will give you a diff. eq. with time as the independent variable. What physical quantity relates position and time? Use the chain rule (implicitly) to convert.
The pleasure was mine!
