Finding Lagrange Point L2: Gravity and Harmonics
The discussion focuses on calculating the distance to the L2 Lagrange point, with a participant reporting a result of 1.5 * 10^9 meters. They seek verification of both the equation used and the accuracy of their distance calculation. Other participants confirm that the equation is correct and encourage further verification through external sources like Google or JWST information sites. The conversation emphasizes the importance of accuracy given the recent attention on L2. Participants are invited to share their findings for additional verification.
jackal123
If an object is placed at a Lagrange point in outer space it will orbit the Sun ‘in concert’ with the Earth. Basically, the combined gravity of the Earth and Sun create the proper force to keep the object “fixed” in the Earth-Sun system. There are five Lagrange points. I’d like you to find the second Lagrange point labeled L2 above. By find I mean determine its distance, d, from the Earth. You may use the mass of the Earth and Sun, as well as the distance between the Earth and Sun.
(GMsun m)/(r+d)^2 + (GMearth m )/(d^2) = m * GMsun / r^3 * (r+d)
So we are finding the L2 Lagrange point, specifically the distance from the earth, or d in this instance. I have used the equation above and I have come out with 1.5 * 10^9 meters as d, or L2's distance from the earth. Can anyone verify this, is the equation correct and is my final distance accurate?
With L2 being so much in the news lately, you should be able to find the distance to check your answer either with a Google search or checking out the JWST info sites. :wink:
Let us know what you find please. If it ends up seeming wrong versus the things you find, we can check your work if you post it in detail. :smile:
Your equation is correct.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
