Finding launch angle from vertical and horizontal distance
In summary: Now make the substitution w = tan(θ), etc. and solve the quadratic equation w = (x ± √(x2+2gy))/(gx).Note that the solution to this problem isn't unique and other solutions may be possible.
vetgirl1990
85
The mountain rescue officers trigger the avalanche by firing a gun at a distant mountain slope.
The muzzle velcoity of the gun is 225m/s. The horizontal and vertical distance from the gun to the slope is
x=1,072m and y=538m respectively. Find the lowest angle between the barrel of the gun and the horizontal plane.
rf = ri + vt + 1/2at2
Dividing each into the horizontal and vertical components:
- Horizontal component: xf = xi + vxt + 1/2axt2
- Vertical component: yf = yi + vyt + 1/2ayt2
Vxi = VicosΘ
Vyi = VisinΘ
I started off by manipulating the equations in terms of time (t), since I don't have that either.
In the x direction, the bullet is under constant velocity, so a=0; xf = 1072m; xi = 0
1072 = 225cosΘ t
(1) t = 1072 / 225cosΘ
In the y direction, the bullet is under constant acceleration due to gravity, ay = -g = -9.8m/s2
528 = 225sinΘ t - 4.9t2
(2) 538 = t(225sinΘ - 4.9t)
Then I substituted equation (1) into (2)...
538 = [1072/225cosΘ] [225sinΘ - 4.9(1072/225cosΘ)
538 = 1072sinΘ/cosΘ - 111.22966/cos2Θ
and this is where the trig substitutions start getting messy. It gets quite long, and I ended up with 1.211249 = sin2Θ, which is impossible.
So either I am approaching the question wrong, or I am not manipulating my trig properly.
Any help or direction would be greatly appreciated.
That has an actual solution, so your mistake is somewhere in the part you didn't show.
Solving for the cosine is probably a bit easier.
Vxi = VicosΘ
Vyi = VisinΘ
1072 = 225cosΘ t
It's not clear how you went from this:
to this:
1.211249 = sin2Θ
It would seem that there is a problem with your algebra of trig here which need double checking.
If it helps any the equation for the distance along the plane is
D = 2 * v^2 ^ cos^2 alpha * (tan alpha - tan beta) / (g * cos beta)
where alpha is the angle of the projectile and beta the angle of the plane.
It would seem that the solution for this particular configuration could be found without deriving this formula,
but I admit to never having tried it.
Incidentally, the equation is derived using
y = - g t^2 /2 + v t sin alpha
x = v t cos alpha
and eliminating the time from these equations.
Good Luck and Happy Halloween!
I've managed to solve it.
If you set everything in terms of tan(theta), then do a substitution, you get a quadratic equation.
Since this hasn't yet been solved I thought it'd be okay to provide my solution, even if this is an old thread.
You got to
538 = 1072sinΘ/cosΘ - 111.22966/((cosΘ)^2)
Which is
538 = 1072tanΘ - 111.23(secΘ)^2
But (secΘ)^2 = (tanΘ)^2 + 1, so
538 = 1072tanΘ - 111.23((tanΘ)^2 + 1)
538 = 1072tanΘ - 111.23(tanΘ)^2 - 111.23
111.23(tanΘ)^2 - 1072tanΘ + 649.23 = 0
Dividing everything by 111.23 we get
(tanΘ)^2 - 9.6377tanΘ + 5.8368 = 0
Substituting tanΘ = u,
u^2 - 9.6377u + 5.8368 = 0
is a quadratic equation with a=1, b=-9.6377, c=5.8368
So,
u = (-b +/- sqrt(b^2 - 4ac))/(2a) = (9.6377 +/- sqrt(92.8853 - 23.3472))/2
u_1 = (9.6377 + sqrt(69.5381))/2 = (9.6377 + 8.3390)/2 = 17.9767/2 = 8.9884
u_2 = (9.6377 - 8.3390)/2 = 1.2987/2 = 0.6494
tanΘ = u
Θ = arctan(u)
There are two solutions
Θ_1 = arctan(u_1) = arctan(8.9884) = 83.6517 degrees = 1.46 radians
Θ_2 = arctan(u_2) = arctan(0.6494) = 32.9997 degrees = 0.5760 radians
Hope I've helped.
Capaverde said:
Hope I've helped.
Yes and no.
It is far better to solve problems symbolically, only plugging in numbers at the end. It has many advantages.
If the displacements are x and -y then we have
x = vt cos(θ)
y = ½gt2-vt sin(θ)
y = ½gx2sec2(θ)/v2- x tan(θ)
y/x = ½gx(1+tan2(θ))/v2- tan(θ)
etc.
Related to Finding launch angle from vertical and horizontal distance
1. How do you find the launch angle when given the vertical and horizontal distance?
The launch angle can be found by using the trigonometric function arctan (tan^-1). Take the inverse tangent of the vertical distance divided by the horizontal distance, and this will give you the launch angle in degrees.
2. Can the launch angle be negative?
Yes, the launch angle can be negative. A negative launch angle would indicate that the projectile was launched downwards instead of upwards.
3. Is there a specific unit for the launch angle?
The launch angle is typically measured in degrees, but it can also be measured in radians. Just make sure to use the appropriate unit when plugging in values for calculations.
4. Does air resistance affect the launch angle calculation?
Yes, air resistance can affect the launch angle calculation. It is important to take into account the effects of air resistance when calculating the launch angle for more accurate results.
5. Can the launch angle be calculated if the vertical and horizontal distances are not known?
No, the launch angle cannot be calculated if the vertical and horizontal distances are not known. These two components are necessary to determine the launch angle using trigonometry.
22K
