MHB Finding Marginal PDFs: Need Help With Integrating Complex Expressions?
  • Thread starter Thread starter nacho-man
    Marginal
To compute marginal PDFs from a joint PDF, integrate the joint PDF with respect to the other variable, specifically integrating f_{X,Y}(x,y) with respect to y to find f_X(x). This process can result in complex integrals, but techniques such as completing the square and variable substitution can simplify the calculations. For example, substituting w = y + (1/2)x√2 can help in evaluating the integral. Utilizing the standard integral of a normal distribution is also beneficial in this context. Proper application of these methods can lead to a clearer solution for the marginal PDFs.
nacho-man
Please see the attached image for my question. I don't understand how to compute the integral, is there some trick?
I do believe that
to find fx(x) I integrate the joint pdf, with respect to x with the bounds set as the range of Y. But this leaves me with a very complex integration
Similarly for fy(y). Is there some trick?
Any help is greatly appreciated.
I do believe that
Hi nacho!
To find $f_X(x)$ you need to integrate $f_{X,Y}(x,y)$ with respect to y.
That is:
$$f_X(x) = \int_{-\infty}^{+\infty} f_{X,Y}(x,y) dy$$
The problem is of course that exponent, but you can complete the square, do a substitution, and use the standard integral of a normal distribution.
That is:
= \int_{-\infty}^{+\infty} \frac{1}{\pi\sqrt 2} \exp\left(-(y + \frac 1 2 x \sqrt 2)^2 - \frac 1 2 x^2\right) dy$$
Can you substitute $w = y + \frac 1 2 x \sqrt 2$?
And use that $$\int_{-\infty}^{+\infty} \exp\left(-\frac 1 2 u^2\right) du = \sqrt{2\pi}$$?
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
