MHB Finding Matrix D Without Calculating P Inverse: Help Appreciated!
  • Thread starter Thread starter tomc612
    Inverse Matrix
tomc612
Hi,
got a question I'm stuck on..
Write down a matrix P which will diagonalise A and write down the corresponding
diagonal matrix D, where D = P^-􀀀1AP. You do not have to calculate P^-1
Ive got all the eigenvalues and eigenvectors for A, and thus have the Matrix P, which has a determinant of -12 and thus P^-1 exists.
Question is how to do you determine D without calculating the inverse of P?
Any help appreciated
Tom
tomc612 said:
Hi,
Tom
The entries on the main diagonal of $D$ are the eigenvalues of $A$. All the other entries in $D$ are zeros.
When you wrote down the matrix $P$, its columns were the eigenvectors of $A$ (in some order). When you write the diagonal elements of $D$, you should use the corresponding eigenvalues in the same order.
I am surprised that tomc612 would be given a problem like this if he had not already learned everything Opalg said!
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
