MHB Finding maximum/minimum values?
  • Thread starter Thread starter eleventhxhour
The function y = 28(1.21)^x is an exponential function that is monotonically increasing due to its base being greater than 1. Therefore, the minimum value occurs at the left endpoint of the interval, which is 28 when x = 0. The maximum value is found at the right endpoint, x = 12, where y reaches its highest point. To find the maximum value, one can evaluate the function at x = 12. In conclusion, the minimum is 28 and the maximum can be calculated by substituting x = 12 into the function.
eleventhxhour
What are the maximum/minimum values for y = 28(1.21)^x on the interval 0 $\le$ x $\le$ 12?
I think that the minimum value might be 28 because y = 28 when x = 0 but I don't know how to find the maximum value. Could someone help/explain? Thanks.
Mathematics news on Phys.org
An exponential function, whose base $b$ is greater than 1, of the form:
$$y=kb^x$$ where $0<k$ will be monotonically increasing on any interval within the domain, which is all reals. Thus, the function will have it's minimum at the left-endpoint and its maximum at the right end-point.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
