Finding maximum number of functions that can be linearly independent
In summary, the conversation is discussing a homework problem in which the maximum number of linearly independent functions on an interval is being questioned. The concept of linear independence is defined, and the conversation delves into different approaches for solving the problem. Ultimately, it is determined that the Wronskian method is not necessary and that examining the functions for linear combinations is the key to solving the problem. The final conclusion is that all five of the given functions are linearly independent.
QuantumCurt
Education Advisor
726
166
Hey everyone. I'm in an introductory differential equations class, and I think this homework problem has got me stumped.
The functions y1(x), y2(x), ... , yn(x) are linearly independent on an interval I. c1y1(x)+c2y2(x)+...+cnyn(x)=0 for all x in I, implies that c1=c2=...=cn=0. What is the maximum number of functions that can be linearly independent?
y1=1, y2=1+x, y3=x2, y4=x(1-x), y5=x
Me and a friend concluded that this was more of a conceptual question. Since it's already defined as being a set of linearly independent functions, we figured that the max number of linearly independent functions must be "n many functions" since it goes up to cn.
I also tried simply adding all of the functions together and setting it equal to zero, then solving for x. This gave me an answer of -2/3, which clearly isn't a logical answer here.
Am I using the right logic in that this is simply a conceptual question, or am I missing something? Do I need to use the Wronskian or do something otherwise involving matrices? Any help would be very much appreciated. :)
You are correct in saying that this is a conceptual question.
Do you have any restrictions on what types of functions are allowed in the space?
If you consider just powers of x, is there a way to add a+bx so that they are equal to zero for all x?
How about higher powers? Is there a maximum power that could be independent such that any higher power of x could be resolved as the sum of lower order terms?
Likes QuantumCurt
Are you asking specifically about the 5 functions above?
If so, try to see if anyone can be made up of the others.
## \sum_{i=1}^n c_i y_i =0 \implies c_i=0 \forall i= 1...n## is linearly independent.
Similarly, if ##y_n ## is linearly dependent, then there exist coefficients
## c_i, \, i= 1...n-1## such that ##y_n =\sum_{i=1}^{n-1} c_i y_i##
Which would mean that
##-1y_n+\sum_{i=1}^{n-1} c_i y_i=0##
Likes QuantumCurt
I worded the problem exactly as it's written on the worksheet. The wording of the problem seems rather confusing to me, as we've seen nothing even remotely like this in my course. I guess I'm just asking about the 5 given functions. I'm not aware of any restrictions on functions that can be used. There's no mention of it in the problem.
Adding a+bx? Are you referring to a method of undetermined coefficients? If so, I don't think that's the method we're supposed to be using. We just saw those for the first time yesterday, and this assignment was given about a week ago. When you say to add a+bx so that they're equal to 0 for all x, are you referring to combinations of the 5 functions, or adding a+bx in such a way that each individual function is equal to 0 for all x?
The first sentence of the problem statement is just defining what linearly independent means. It isn't telling you that the functions are given are linearly independent. You are supposed to figure out the maximum number of function in that set can be linearly independent.
Likes QuantumCurt
Is that what it's asking? That makes a lot of sense. That seems like a far more logical type of question to ask. If that's the case, this is a much simpler matter. Thanks for pointing that out. This explains my confusion.
Am I right in thinking that the Wronskian is going to be my best bet for solving this? Should I set up a matrix with all 5 functions?
##W(y_1, y_2, y_3, y_4, y_5)=\begin{vmatrix}
1&1+x&x^2&x-x^2&x\\
0&1&2x&1-2x&1\\
0&0&2&-2&0\\
0&0&0&0&0\\
0&0&0&0&0
\end{vmatrix}##
And then just find the determinant of this 5x5 matrix? That sounds like a rather daunting task. It's seeming like it may be simpler without the Wronskian. Any thoughts?
Okay, forget the Wronskian. I was over complicating that. This is where I'm at now.
##c_1+c_2(1+x)+c_3x^2+c_4x(1-x)+c_5x=0##
Now I just need to examine it to determine if any of the functions are constant multiples of another function, right?
That being the case, there are no functions in this set that are constant multiples of another one of the functions, thus proving that all 5 of the functions are linearly independent? That seems too simple.
edit-
I'm concluding via this relation that all 5 of the functions are linearly independent, but when I plug this matrix into Wolfram and find the determinant, it's coming out as equaling 0. This would imply linear dependence. So I'm getting different answers via the different methods. What am I doing wrong?
The matrix in Wolfram - https://www.wolframalpha.com/input/...0,+2,+-2,+0},{0,+0,+0,+0,+0},{0,+0,+0,+0,+0}}
You're trying to determine if any of the functions can be written as a linear combination of the others, not just multiples of the others.
The determinant of that matrix is obviously 0 because there's a row of zeros.
(sorry for posting so many times in a row)
I think I'm figuring out where I went wrong. If I take the first and second derivative of the relation -
I get -
##0+c_2+2c_3x+c_4(1-2x)+c_5=0##
and
##0+0+2c_3+0-2c_4+0=0##
Which implies that
##2c_3=2c_4 ##
and that
##c_3=c_4##
So this implies that at least functions 3 and 4 are linearly independent, correct?
Since $$y_1+y_5=y_2$$, or
##1+x=1+x##
This implies a linear combination that can equal zero, correct? Does this imply that functions 1, 2, and 5 are linearly independent?
No, it says ##y_1##, ##y_2##, and ##y_5## are linearly dependent. Independence requires that ##c_1 y_1 + c_2 y_2 + c_3 y_5 = 0## has as its only solution ##c_1 = c_2 = c_3 = 0##, but you've just shown that ##c_1 = 1##, ##c_2 = -1##, and ##c_3 = 1## is a possible solution.
Okay, I see. I was mixing the terms up. It's been a long night. -_-
So since these three functions are linearly dependent, and functions 3 and 4 are linearly independent, would I say that the maximum number of linearly independent functions is 2? Or is there still more to it? I'm not seeing any other combinations that would work.
I can see by inspection that y1 = 1, y2 = 1 + x, and y3 = x2 are linearly independent. That's three functions.
I'm not seeing this. How are they linearly independent?
I don't think my instructor ever adequately explained how to figure this out, and my textbook barely even touches on it.
Would I take a linear combination such that $$x^2+x+2=0$$, which shows that the function has zeroes for constant multiples of 1?
##c_1+c_2+c_2x+c_3x^2##
Given constant values of 1, this becomes the aforementioned quadratic function with non-zero roots.
edit-never mind. It's getting late and I'm not thinking right. That function would only have non-real roots.
That's not the question to ask. The question to ask is, Does the equation c1 * 1 + c2 * (1 + x) + c2 * x2 = 0 have any nontrivial solutions for the constants?
Every such equation always has the trivial solution, c1 = c2 = c3 = 0, whether the functions are linearly independent or linearly dependent. For these three functions to be linearly independent, the trivial solution is the only solution, independent of x. Note the "for all x in I" phrase in the definition you wrote in post #1.
The equation you wrote, x2 + x + 1 = 0 is irrelevant to the discussion, since the equation for linear independence has to hold for all x. (It's also not relevant that this equation doesn't have real solutions.)
Again, the roots of a polynomial have nothing to do with this.
Linear independence is not that they can't equal zero ever, but that they don't equal zero always.
With the functions provided, this is addition. Start with the first. One function is always linearly independent.
Check if the second can be written as a constant multiple of the first.
Then check if the 3rd can be written as a sum of constants times the first 2, etc.
Alternatively, write the system as a matrix and row reduce. The number of non-zero lines is the number of linearly independent functions.
Okay, I get what you're saying. I'm just not sure how to go about proving that it doesn't have any nontrivial solutions. I don't see any way of solving this equation to show that. Is a solution to the equation even a part of this process, or is it more of a process of inspection?
This may be a technique that we haven't looked at yet. This doesn't sound like anything that we've seen in this course yet.
In either case, I'm done for the night. It's bedtime. Thanks for the help, everyone. I'll tackle it again tomorrow.
I think it is more an inspection, similar to the determinant test you already mentioned.
You can often show dependence of functions one at a time and kick them out of the system.
What remains can be checked with a variety of methods to test for independence.
As was said in an earlier post, 1+x= 1+x. That means one of the three functions (1) (x) (1+x) is dependent and can be removed from the system.
Have you done any work checking whether a set of vectors is linearly independent yet? If so, doing the same with a set of polynomials is only slightly different.
Your set of polynomials can be thought of as these vectors in ##\mathbb{R}^3##:
$$\{ \begin{bmatrix} 1 \\ 0 \\ 0 \end{bmatrix}, \begin{bmatrix} 1 \\ 1 \\ 0 \end{bmatrix}, \begin{bmatrix} 0 \\ 0 \\ 1 \end{bmatrix}, \begin{bmatrix} 0 \\ 1 \\ -1 \end{bmatrix}, \begin{bmatrix} 0 \\ 1 \\ 0 \end{bmatrix} \}$$
We haven't done anything with vectors in this course. This is a 200 level introductory course (I'm in a community college). Aside from using vectors within my physics courses, I haven't done anything with them. Definitely not in the capacity that you're referring to here. After I transfer, I'll be taking an upper level diff eq course, as well as linear algebra. So I imagine I'll be getting plenty of exposure to them soon enough.
I should also point out that I haven't taken calc 3 yet. That'll be next semester.
Gotcha, these skills will be useful as you progress.
The important thing to notice is that if a set of vectors are not linearly independent, there is at least one which doesn't add anything new to your system.
For example if I told you that x=1, y=3, and x+y=3, the last bit doesn't tell you any more.
Linearly independent systems have nice properties that redundant systems do not.
FAQ: Finding maximum number of functions that can be linearly independent
What is the definition of linear independence?
Linear independence is a property of a set of functions or vectors, where no function can be expressed as a combination of the other functions in the set.
Why is finding the maximum number of linearly independent functions important?
Finding the maximum number of linearly independent functions is important because it helps determine the dimension of the vector space spanned by those functions. This, in turn, can provide important information about the properties and behavior of the functions.
What is the process for finding the maximum number of linearly independent functions?
The process for finding the maximum number of linearly independent functions involves creating a matrix with the given functions as rows, and then using row reduction techniques to determine the number of linearly independent rows. The number of linearly independent rows is equal to the maximum number of linearly independent functions.
Is it possible to have an infinite number of linearly independent functions?
Yes, it is possible to have an infinite number of linearly independent functions. For example, the set of all polynomials of different degrees is an infinite set of linearly independent functions.
Can two functions be linearly independent if they are equal?
No, two functions cannot be linearly independent if they are equal. In order for functions to be linearly independent, they must be unique and not able to be expressed as a combination of each other.
