Finding maximum speed (known: Force output, drag, time)
In summary, the conversation discusses the relationship between drag force and the speed of an object moving through a dense fluid, as well as the maximum speed of a boat with a motor that can output 450 Newtons of force. The individuals also consider Newton's laws of motion and use equations to determine the mass and acceleration of the boat. However, it is noted that the problem statement is missing crucial information.
JohnLCC517
1. In general, dense fluids (such as water) produce a drag force that is directly proportional to the speed of an object moving through them. Suppose a boat is moving through the water and experiencing a fluid drag force of F=-8 v. Suppose the boat has a motor which can output up to 450 Newtons of force. What is the maximum speed of the boat? If the boat starts from rest at t=0, find the speed of the boat as a function of time.2. To get started I am inclined to find velocity, however, I am not aware of any way in which I can find velocity from force (the 450 Newtons of force output by the motor).3. My initial attempt would be to enlist Newton's 3rd law and set up the equation 450 N = 8v (negative sign removed since the velocity will be measured in the positive direction. From there I could find v as follows; (450 N/8) = v which would further suggest that v = 56.25 N. This would create a drag force equal to the force propelling the boat through the water. From here I'm thinking that I should put my findings into a kinematics equation but there appears to not be enough information to do so. Am I missing something crucial?
Yes, quite crucial.
How does anybody starting from rest attain a velocity, i.e., what must happen to that body in order to change the velocity over a period of time from zero to a finite value?
Didn't a chap called Newton have something to say about how forces acting on a body change its motion?
Likes JohnLCC517
Units?
Correct. The problem statement is missing something crucial.
SteamKing said:
Yes, quite crucial.
Guessing that you are alluding to Newton's first law of motion. An external force must act upon an object to change its acceleration vector from zero. In this case the motor is the external force. From there I move to Newton's second law of motion which states "The acceleration of an object as produced by a net force is directly proportional to the magnitude of the net force, in the same direction as the net force, and inversely proportional to the mass of the object" or the infamous F = ma equation. Knowing the force = 450 Newtons, and that the force in the negative direction (in this case the drag) has to be equal to the Force in the positive direction (due to Newton's 3rd law) I can set up the equation 450 N = -8v which, when manipulated, suggests to me that the mass of the boat is 56 kg and the acceleration is 8 m/s2. Does it seem like I am on the right track?
Newton's second law of motion is
FNET = ma = m (dv/dt)
You are given that the boat motor can produce a thrust of 450 N and that the drag force countering the boat's motion is proportional to the boat's velocity, such that Drag = 8v
What is the net force acting on the boat when it is in motion at speed v?
How is that net force related to the speed of the vessel?
BTW, there is no direct correlation between the mass of a boat and how much thrust its motor can produce.
Related to Finding maximum speed (known: Force output, drag, time)
1. What is the formula for calculating maximum speed?
The formula for calculating maximum speed is: maximum speed = force output / drag.
2. How can I measure force output and drag?
Force output and drag can be measured using force meters and drag meters, respectively. These devices measure the amount of force and resistance exerted on an object.
3. Can I find maximum speed if I only know the force output and drag?
Yes, you can find the maximum speed if you know the force output and drag. However, it is important to also consider other factors such as the weight and aerodynamics of the object to get a more accurate result.
4. How does time affect maximum speed?
Time does not directly affect maximum speed. However, the longer an object is subjected to a force and drag, the more it will slow down due to the accumulated resistance.
5. Are there any limitations to using this method for finding maximum speed?
Yes, this method is based on theoretical calculations and may not always accurately reflect real-world situations. Other factors such as air density, surface conditions, and external forces can also affect the maximum speed of an object.
