Albert1
- 1,221
$a,b,c,d,e \in R$
$a+b+c+d+e=8$
$a^2+b^2+c^2+d^2+e^2=16$
$find :\,\, e_{max}$
$a+b+c+d+e=8$
Albert said:$a,b,c,d,e \in R$
$a+b+c+d+e=8$
Albert said:$e_{max}=?$
and can you prove it ?
The maximum value of e in the given set of real numbers cannot be determined without knowing the specific values of a, b, c, and d. Each of these variables can affect the maximum value of e.
The maximum value of e can be calculated by finding the derivative of the function f(e) = a*e^4 + b*e^3 + c*e^2 + d*e and setting it equal to 0. Solving for e will give the value of e that maximizes the function.
There is no specific formula for finding the maximum value of e in a given set of real numbers. It depends on the specific values of a, b, c, and d.
Yes, the maximum value of e can be negative if the values of a, b, c, and d are such that the function f(e) = a*e^4 + b*e^3 + c*e^2 + d*e has a maximum value at a negative e value.
The maximum value of e is affected by the values of a, b, c, and d. Changing any of these variables can result in a different maximum value of e. In some cases, increasing one variable may lead to an increase in the maximum value of e, while in other cases it may lead to a decrease.
