Finding minimum concentrations in a buffer solution
In summary: So adding the acid brings it up to 3.7 and all the formate is converted to HCOO- (or H2CO3 if you are adding a base). This was slightly more work than just solving the equilibrium equations, but as I said it is a bit more practical to be looking for insights than blindly applying a formula.
SM8806
"Calculate the minimum concentrations of formic acid and sodium formate that are needed to prepare 500.0 mL of a pH 3.80 buffer whose pH will not change by more than 0.10 unit if 1.00 mL of 0.100 M strong acid or strong base is added."
Ka of formic acid = 1.8E-4
pKa of formic acid = 3.74
Henderson-Hasselbalch equation: pH = pKa + log([base]/[acid])
So...the initial concentration of H3O+ in the pH 3.80 solution would be 10^-3.80 = 1.58E-4 M. In a 500 mL solution, it is: 500 mL x 1.58E-4 mol / mL = 0.079 mmol H3O+. The thing is, I'm not sure how to apply this.
Alternatively, knowing the pH and pKa of the acid, I can use the Henderson-Hasselbalch equation: 3.80 = 3.74 + log([base]/[acid]). The resulting ratio is 0.871. I am unsure how I would be able to use this to calculate the concentrations of acid and salt (base). If we are adding .100 M strong acid (or base), the resulting pH would be 3.70 (or 3.90), correct? Using 3.70 as the pH in the H-H equation, the resulting ratio is 0.912.
I'm just really lost. Thanks for any help!
Be a bit precise to not lose marks and risk also confusing yourself. You mean to say here that the 500 ml solution contains 0.079 mmoles of H3O+ (which I will call H+). It is still 1.58E-4 M (that is its H+ concentration) or rather molarity. I personally would rather think in molarities, so think of adding 2ml to 1l and divide by 2 at the end. Also to avoid any thing else superfluous work out how to get to exactly pH 3.7.
To be asking you a slightly tricky, though perfectly and typically practical question like this, they are testing for a bit of insight instead of blind application of a formula, to see if you can see you do have in the problem all the information needed to solve the question (and without making it more complicated than necessary).
You have worked out the ratio [base]/[acid]. Which is equal to what?
To [Na+]/[HCOO-] in your original pH3.8 solution.
You know the ratio of these two things, but you do not know their absolute amounts because the latter can be anything (as long as they in that ratio and also are well above your proton concentration of the order of 10-4M).
The only thing you know the absolute amounts of is the 2ml of strong acid or base to be added.
Maybe you can start from your acid base ratio at pH 3.7 as you did, but I see clearer to just ask again what is [H+] , this time at pH 3.7?
Those extra protons compared to those at pH 3.8 have to be balanced by something extra of opposite charge, which is actually the Cl- (or other anion) of the strong acid you add. And that number are in your added 2 ml. Likewise when you go in the opposite direction and increase the pH - well you work it out.
Hopefully this gets you moving, not time to finish this off nicely at this instant.
NOTE - I HAVE MODIFIED THIS POST SINCE PREVIOUS VERSION TO CORRECT SOME ERRORS
I have to thank you for the fact that it is after some decades of believing that that thing was the Henderson Hasselbach equation I whilst doing your problem looked it up and found the name was Hasselbalch as you have written, and that I am far from the only one who thought that. I think it is OK to outline how I got result.
First I work out [H+] at pH 3.8 as you have and at 3.7.
Then from the equilibrium equations I work out [HCOO-]/[HCOOH] as you have, but for both pH's (I get slightly different from you, please check). Except I wouldn't bother with Henderson-Hasselbalch, you have got the equilibrium constant.
I then express in both cases [HCOO-] as a fraction of total of both forms of formate, i.e.
[HCOO-]/([HCOO-] + [HCOOH]).
(The denominator is constant, being the total amount of formate plus formic acid, and this stays constant as we change pH by adding acid or alkali, though we don't know what it is yet.)
The difference between the two is the fraction of all formate that changed from HCOO- to HCOOH when we added our 0.2 mmoles of strong acid. I get that to be 0.057 of the formate. But a litre of 0.057 of the formate has to equal the 0.2 mmoles of acid, we added. Actually to be accurate we have also to add in the H+ increase in going from pH3.8 to 3.7 which is not negligible, this is what is mentioned in the first line of calculation above and I calculate 4.1X10-5M or 0.041 mM. In short, electroneutrality of change demands the Cl- added equal the HCOO- that disappears + the H+ that appears. (The only other substantial presence here, the Na+ doesn't change.) So the total formate has to be (0.2+0.041)/0.057 = about 4.2 mM. I am quite error-prone so see if you get similar. You know the ratio base/acid so you can calculate how much of each you need to make a 500ml buffer solution.
I hope the idea makes sense, as natural way to make this calc. The concentration for a change 0.1 pH unit the other way when adding strong base should be practically the same. If you do an exact calculation I think you will find them very slightly different, perhaps you can explain that. You may find in your books something about 'buffering capacity' with formulae, which puts the present kind of calc. into a formula, but you need to be able to do this without that.
Notice you have added 0.2 mmole/l of strong acid but the change in [H+] is only about 4X10-5M. That is what a buffer does, mop up most of the added H+.
SM posted this question both here and on chemicalforums. It happened I have answered it there first with hints, but SM have not visited the site since.
Not that s/he visted PF to check if anyone answered...
To calculate the minimum concentrations of formic acid and sodium formate for the buffer solution, we can use the Henderson-Hasselbalch equation: pH = pKa + log([base]/[acid]). In this case, the pH is given as 3.80 and the pKa for formic acid is 3.74. We can rearrange the equation to solve for the ratio [base]/[acid], which is equal to 10^(pH-pKa). This gives us a ratio of 0.871, meaning that for every 0.871 moles of sodium formate, we need 1 mole of formic acid to make the buffer solution.
To calculate the minimum concentrations, we can use the formula c = n/V, where c is the concentration, n is the number of moles, and V is the volume. For a 500 mL solution, we need 0.871 x 0.5 = 0.435 moles of sodium formate and 0.5 moles of formic acid. This translates to concentrations of 0.871 M for sodium formate and 1 M for formic acid.
To ensure that the pH does not change by more than 0.10 units when 1.00 mL of 0.100 M strong acid or base is added, we need to consider the change in moles of acid and base. For strong acid, 1.00 mL of 0.100 M HCl will add 0.100 mmol of H3O+ to the solution. This would change the pH to 3.73, which is within the specified range. Similarly, 1.00 mL of 0.100 M NaOH will add 0.100 mmol of OH- to the solution, resulting in a pH of 3.87, which is also within the specified range. Therefore, the concentrations of formic acid and sodium formate that we calculated earlier meet the given criteria.
Related to Finding minimum concentrations in a buffer solution
1. What is a buffer solution?
A buffer solution is a solution that resists changes in pH when small amounts of acid or base are added to it. It is typically composed of a weak acid and its conjugate base or a weak base and its conjugate acid.
2. How is the minimum concentration in a buffer solution determined?
The minimum concentration in a buffer solution is determined by calculating the minimum amount of acid or base required to maintain a specific pH level. This is done using the Henderson-Hasselbalch equation, which takes into account the pKa (acid dissociation constant) of the weak acid and the ratio of its conjugate base to acid.
3. Why is it important to find the minimum concentration in a buffer solution?
Finding the minimum concentration in a buffer solution is important because it allows for the precise control of pH in a solution. This is especially important in biological and chemical reactions, as many enzymes and other molecules are sensitive to changes in pH.
4. What factors can affect the minimum concentration in a buffer solution?
The minimum concentration in a buffer solution can be affected by several factors, including temperature, ionic strength, and the concentrations of the weak acid and its conjugate base. Changes in any of these factors can alter the buffering capacity of the solution.
5. How can the minimum concentration in a buffer solution be optimized?
The minimum concentration in a buffer solution can be optimized by carefully choosing the weak acid and its conjugate base, as well as their concentrations. Additionally, maintaining a consistent temperature and ionic strength can help to maximize the buffering capacity of the solution.
