MHB Finding missing point of a vector when it is perpendicular to a line
To find the coordinates of point B on line L1 such that vector AB is perpendicular to L1, the scalar product of vector AB and the direction vector of L1 must equal zero. The coordinates of point B can be expressed in terms of parameter t, leading to the equations for the components of vector AB. Substituting these into the scalar product equation yields a quadratic equation in t, which can be solved to find the values of t. The solutions indicate that t can be either 3 or -2, leading to the coordinates of point B being determined based on these t values. The discussion emphasizes the relationship between the vectors and the conditions for perpendicularity in vector geometry.
AJTheRed
The question:
The line L1 has equation $$r = \left( \begin{array}{ccc}4 \\-1 \\0\\\end{array} \right) + t\left( \begin{array}{ccc}1 \\1 \\-1\\\end{array} \right) $$, and point A has coordinates (4, 8, -3).
Find the coordinates of point B on L1, such that $$\overrightarrow{AB}$$ is perpendicular to L1.
My attempt to answer:
I know that $$\overrightarrow{AB} \cdot \left( \begin{array}{ccc}4 \\-1 \\0\\\end{array} \right) + t\left( \begin{array}{ccc}1 \\1 \\-1\\\end{array} \right) = 0$$. I also know that this scalar product has to do with finding point B. I also know that $$\overrightarrow{AB}$$ = $$B-A$$ = $$B - \left( \begin{array}{ccc}4 \\8\\-3\\\end{array} \right)$$ and I think that $$\left( \begin{array}{ccc}4 \\-1 \\0\\\end{array} \right) + t\left( \begin{array}{ccc}1 \\1 \\-1\\\end{array} \right) = \left( \begin{array}{ccc}4+t \\-1+t \\0-t\\\end{array} \right)$$. If all of this is plugged into the scalar product, we get $$\left(B - \left( \begin{array}{ccc}4 \\8\\-3\\\end{array} \right)\right)\cdot \left( \begin{array}{ccc}4+t \\-1+t \\0-t\\\end{array} \right) = 0$$, which can be rewritten as $$V_{1}W_{1} + V_{2}W_{2} + V_{3}W_{3} = 0$$ or $$((B_{1}-4)(4+t))+((B_{2}-8)(-1+t))+((B_{3}-(-3))(-t)) = 0$$. Assuming that I've done everything above correctly, what I am struggling with is figuring out how to go about finding the B and t values so that the scalar product is equal to zero. Any hints as to a mistake or mistakes I may have made or what I should do next is very much appreciated and I thank you for taking the time to read through this whole question to lend some support.
Mathematics news on Phys.org
AJTheRed said:
The question:
$\displaystyle \begin{align*} B \left( b_1, b_2, b_3 \right) \end{align*}$ is a point on $\displaystyle \begin{align*} \mathbf{r} \left( t \right) \end{align*}$, so we can write $\displaystyle \begin{align*} b_1 = 4 + t , \, b_2 = -1 + t , \, b_3 = -t \end{align*}$. Thus the direction vector $\displaystyle \begin{align*} \vec{AB} = \left( 4 + t - 4 , -1 + t - 8 , -t - \left( - 3 \right) \right) = \left( t , -9 + t , 3 - t \right) \end{align*}$
Since we know $\displaystyle \begin{align*} \vec{AB} \end{align*}$ is perpendicular to $\displaystyle \begin{align*} \mathbf{r}\left( t \right) \end{align*}$, that means
$\displaystyle \begin{align*} \left( 4 + t, -1 + t , -t \right) \cdot \left( t , -9 + t , 3 - t \right) &= 0 \\ t\left( 4 + t \right) + \left( -9 + t \right) \left( -1 + t \right) + \left( 3 - t \right) \left( -t \right) &= 0 \\ 4\,t + t^2 + 9 - 9\,t - t + t^2 - 3 + t + 3\,t - t^2 &= 0 \\ t^2 - t + 6 &= 0 \\ \left( t - 3 \right) \left( t + 2 \right) &= 0 \\ t = 3 \textrm{ or } t &= 2 \end{align*}$
If $\vec{AB}$ is perpendicular to the line $L_1$, we should have that $\vec{AB}$ is perpendicular to the direction vector $\begin{pmatrix}1\\1\\-1\end{pmatrix}$, shouldn't we? (Wondering)
That means that we should have:
$$\vec{AB} \cdot \begin{pmatrix}1\\1\\-1\end{pmatrix} = 0$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
